AP Mode or Routing mode
Woody70
Jun 9, 2020
168
37
Hemet California
I have my camera setup in routing mode. Is AP mode better for wireless or stick with routing mode? Also in the camera settings it has these three settings for night vision Double light vision - infared vision and Full Color Vision. I have it in infared now and I do not want full color vision but I can't find out anything what double light vision is. Does anyone know. Thank you for any help.
Would help anyone who might know if you said what camera and included that in the thread title.
Reactions: TonyR
I'd stick with what's working.
I'll go out on a limb here and say that "Routing mode" is likely how most wireless cams have operated for some time, meaning they obtain an IP from your LAN's router via DHCP.
If so, then it traditionally has been called "infrastructure" mode.
"AP mode" quite possibly means that the cam broadcasts a SSID (a wireless signal name) and has a static IP; you log onto it with another wireless device set to a static IP in the same subnet as the AP; a username and/or password is required.
Traditionally this was called "Ad hoc" mode.
If I am correct about the above info, they have worked well for a long, long time without having to be re-named. :cool:
** spam links removed **
That makes sense, thanks for the clarification. Sticking with routing mode does seem like the simpler and more stable option unless someone really needs AP for a specific setup. I appreciate the extra tip too—I’ll take a look at that site. Always good to learn new ways to streamline things.
What is the camera make and model? :idk:
