Anyone using Vivotek VS8100 with Blue Iris ? Looking for Compatability Advice.
ibrettj
Aug 14, 2014
4
Hi Guys
I'm interested if anyone is using the Vivotek VS8100 with Blue Iris to do all the capture work. I'm trying to find a low cost ip pinhole camera option and combining this with an analogue pinhole camera seems to be much cheaper and quite a bit smaller than some of the ready made pinhole ip cameras like the Hikvision or the Axis.
What i'm after is any advice on whether the Vivotek server will be compatible with Blue Iris. I'm guessing that as BI supports the Vivotek RTSP mode that it should work. I'll probably look to get a couple of these and install them with the different camera's linked directly back to the IP network.
Any suggestions/advice would be much appreciated.
Thanks
