- Aug 16, 2015
- 98
- 40
If I perform the following trace from a command prompt:
tracert mydomain.noip.org
Tracing route to mydomain.noip.org [8.23.224.90]
It always resolves to 8.23.224.90 If you run a trace on yours, what does it resolve to?
My actual IP address is different, Example -> [106.200.35.65] and BI is setup on port 8085
If I go to mydomain.noip.org I get the BI login but absolutely nothing else. If I go directly to 106.200.35.65:8085 (the raw address and port) I get everything.
It's been working for months without a problem. I just started having issues a few days ago after updating to BI 4.2.8.2. Does anyone know if this might be affecting it?
EDIT:
Figured it out... For some inexplicable reason, the update to BI 4.2.8.2 changed my firewall settings. As soon as I changed them back everything started working like it did before the upgrade.
Please disregard!
