Anyone using Images in the camera OSD?
Jan 1, 2024
821
405
USA
So I have in the past setup my image to work with my cameras. I reset them all the time and so I have been only adding back Revo2Maxx in the OSD. However thought I would put my image back. Now before when I did this I didn't have email setup to get events snapshots and now I do. However the image that I have on my camera is red but the snapshot I am getting the image in Blue? If you are using an image in your camera does this also happen to you? Is this some type of P-Frame or another frame that isn't normal live view? I mean most people I have noticed don't even personalize the Watermark and I think others are using custom OSD images?
Just wondering if it just happens this way? Anyone know?
First picture is from live view and second picture is from email event snapshot?
I don't use a personal image on any cameras, cannot see the point.
Perhaps your change in colour is self adaptive, due to the bright/darker image.
Understand.. Again most people don't bother to change the Watermark or even turn it off.. I know it only works with DAV and I don't normally export in Dav anyway but I do have it setup in all my cameras and if I ever needed to share footage for court I would export in DAV to have proof that footage was not changed from exported format..
My main issue with the blue on the export of the picture is that it is only in Email. So I thought maybe it is how the Snapshot is sent for email with the setting only on 5 so I changed to 6 and still only blue. So maybe they have something changed in the email export with RGB being maybe BRG or who knows.. I was just wondering.. if it was normal.. The images that are saved on the camera MicroSD card are the correct ones so don't really have an issue as the email is really only as a backup for time stamp of an event that I can then have fast access without having to do a search. I can just look at emails, find what I want to playback and work off that as a time stamp..
Thank you for your reply I just like to understand any and all I can about what and how things are working..
