Anyone use the "Fast-Moving" IVS setting?
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
Curious how well this works for capturing vehicles as they drive through the FOV. Thanks!
This is simply a method to filter out "slow moving" objects.
Plain ole IVS is probably the better option for most people and it would have to be a particular use-case why someone would only want triggers for fast moving objects.
Thanks @wittaj... I guess my hope was that somehow this setting would do a better job capturing moving vehicles. With regular Intrusion, the snapshot is late more times than not and misses the vehicle.
Yeah, I suspect this would be even worse as it now would have to run it thru the algorithm to determine if it is "fast".
I have one camera that is problematic like that so I am using Deepstack to get the vehicle in the middle of the snapshot. Since the camera AI is doing the main analysis, it does it fairly quickly.
Reactions: 105437
I've wondered about that one too. Never tried it but I could see someone maybe using it to capture vehicles moving above some relative speed vs others. The sensitivity for that seems to relate to speed so that might work as a filter. You'd have to play with it to get the threshold right for whatever speed you're trying to tag.
