So, as I learn my way through, you guys know that only the weirdest crap happens to me...
and that's cool... I'm learning a lot cause of it...
So, here's the latest strange issue I have:
1. BI push notifications work and have worked perfectly, up until yesterday. As in, they come in quick, they have an alert image with the DS mark up, but this is now ONLY happening when I toggle to Cellular network! When I go to my Wi-Fi, most often I'm getting slowish push notifications, and the alert images just don't show up! Once in a random while they will, but mostly not!
Here's what possibly has changed:
1. I swapped a router late last night that sits directly in front of the BI machine. This router is giving funky IP assignment issues when I connect to its SSID. I have DHCP turned off APs throughout my house and this is one of them. DHCP comes straight from my ISP's gateway modem that's been working well for about a week, until last night. Reverting this back to a better quality router is not solving this issue.
2. I also upgraded the BI version to the latest stable from the Golden version of 5.4.6.3 in persuit of the custom models. I failed, as the notifications issues were back and custom models didn't work. During this use, I noticed this no images issue. So I rolled back. The notification BI issues were gone for one of my cameras, however, this push notifications issue hasn't gone!
I have tried:
Rolling back BI. Rebooting gateway. Rebooting APs. Swapping APs. But nothing makes it work consistently. The only thing that works like lightning is when I'm on cellular data... Then everything flows like it used.
Has anyone seen this nonsense before? If so, did you ever find a fix and if you did, what was it?
Appreciate the help thanks!
I have tried:
