Anyone mount security cameras out in the yard?
Sybertiger
7,399
23,538
Orlando
Curious to know if any of y'all have mounted security cameras out in the yard. I know the topic of security cameras at the mailbox or LPR cams near the street have come up. I was thinking about maybe having a security camera 20 feet from the front of the house looking back at the house and specifically looking at what packages are left at the front door.
But then again, a camera mounted on a pole 5 feet off the ground probably would not be the most attractive feature...and mounting one 18" off the ground might be a bit too low although not visually as obvious from the street.
Would love to see some pictures of security cameras mounted in the yard.
I have mounted them to trees. I painted them brownish to blend in.
Can you share a pic of them mounted on the trees?
2" pipe to junction boxes, 4x4 post 10 feet installed, used shielded Cat6 - ran extra wires to each post. I wanted four cameras looking back at the home. Your own install will vary but that is what I did and never had an issue with weather.
