- Aug 7, 2017
- 418
- 226
The PFA-121 is the standard dahua junction box for HFW series camera with a square base. The problem is, this J-box is way to big for my application because I need to mount two of them side by side next to a eave. The eave size is not capable of fitting two of these. So I need something smaller or perhaps a single J-box that spans 8 inches wide max and can support 2 cable glands.
As you can see in the picture, there is a ton of wasted space comparing the base of the bullet cam to the surface area of the j-box.
