- Jul 31, 2017
- 3
- 0
I bought Laview LK-KN988P84A4 system for my business and only the NVR and 2 camera used.
Picture quality is decent to see what happened.
So I am plan to install remain 2 cameras (model LK-PB932F4) at home to see what happened.
Additionally, I want to buy another 2 "better" IP Hikvision camera to ID'ing someone and
NVR to record all the 4 cameras. (I don't need more than 4 cameras)
About the Hikvision camera.
I don't care the shape of the camera(dome or bullet). It will install exterior wall.(no awning)
I strongly hope the camera can be turn on/off night vision permanently.
I noticed sometimes night vision make a worse video quality. My street is always light on,
so night vision is not important, but need to turned on/off manually.
And absolutely clear image needed.
Price range may be around $200 per camera, but not absolutely.
Any NVR that records 4 cameras above without problem will be OK.
I will buy them separately instead of all in one system that sells NVR+cameras in one box
because I heard that bundled camera usually lower spec than sells separately.
Any idea?
Any idea?
