Anyone having recent OpenVPN problems?
bigredfish
29,057
74,091
The Swamp
For some reason I can’t connect to any of my OpenVPN servers over the past week or so.
I use the OpenVPN client on Win11 and have used it for years. Have server setup on 6 different remote routers to access NVRs on those networks. No change on the remote networks and it’s ALL of them
Problem is local to me. As if some software (windows or Bitdefender?) may have updated and messed something g up.
Router and firewall logs here show initial outbound connect (not blocked) as does the OpenVPN client, but it won’t truly connect as if no response from remote server.
I think my client isn’t sending the full command or responding to the handshake.
Only message in client log is “server poll timeout”
Just thought it worth asking if anyone else has seen this recently?
I just tried mine and could connect to every system I help with.
Only thing I can think of is a windows update changed your network from public to private (or vice versa). I forget which way it does but Windows updates tend to change that with no warning.
That’s my thought, I turned off everything I can think of in Bitdefender and my firewall shows a good initial outbound connect but obviously the handshake is dying as if my laptop isn’t getting the handshake response.
I don’t have those on my phone, remote routers/NVRs I maintain/help on but don’t usually use phone to do it.
I could go Nextdoor and try their network to verify but I think it’s on my machine
Reactions: 97JeepXJ
Well I did have that issue last week and I couldn't connect - the elderly neighbor accidently unplugged the router, but for you to have all 6 do that is statistically impossible lol
I just have it as backup, WireGaurd is my primary way in now. It (OpenVPN) should probably be setup on my laptop too though
yeah I use Wireguard for accessing my home network and it works great. Faster than OpenVPN, but the routers I'm connecting to remote are older Asus with just OpenVPN as an option
Try to connect from other device on your home network, to know if this is a network issue or device specific issue.
You can do that by using you smartphone as a client or doing live boot for Linux on your PC (but installing app on your smartphone is much faster).
I also moved to Wiregaurad a while ago (a few years) and don't use windows.
Check the PRIVATE vs PUBLIC settings on your network card. I seem to recall mine changed on it's own after an update or modem swapout of something along those lines.
