I have not purchased the system or started install yet, but wanted to know if this type of install could be a problem. This would be a 400'+ run, likely a Dahua ePoE NVR with the Dahua N45EF63 4MP ePoE Outdoor Bullet IP Security Camera with Night Color Technology.
One time I talked with the Power Co. guy right about where this picture would have been taken. He had an EMI meter (or something similar) and was showing me that the readings were very high. Unless all this EMI stuff is just tin foil hat in nature, I would definitely use a shielded cable and ground it as instructed. They even make a Cat8 with better shields than the Cat6.
What has been your experience with EMI?
Cat8.2 Cable
CAT8 Shielded RJ45 Field Termination Plug
Cat8.2 Cable
