Has anyone had any new success connecting the Swann NHD-815 cameras to BI?  My buddy has a Swann NVR8-7300 and (4) cameras.  The images fit fine on a monitor in a 4x4 matrix.  When we went to add a 5th camera the matrix went to 3x3 with 5 cameras and 4 black screens and he hates it.  I contacted Swann and they said there are no options for displaying 2x4 or floating adjusting like the BI web app does.  Any number of cameras over 4 goes to a 3x3 matrix.
I took camera #5 home and am trying to connect it to my BI installation.  According to the Reolink app it is an "IPC_388M" camera and according to nmap it is only listening on port 9000.  I have tried the settings above but no luck (but I'm no BI wiz, either).  I have also tried using Amcrest 960H and IPC setups with no luck.
 I know these cams are not the best but he would rather repurpose the 5 Swann cameras on a new PC with BI than buy 5 new cameras (senior citizen, fixed budget).
Any new ideas?  A screen shot would be appreciated.  Thanks.
