fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
@nayr...the OP has 8 VGA cameras...he will not be able to tell the difference...do the math...the pixel loss is about 10 percent in a matrix view ....
As far as 1080p cameras, if you sit directly in front of the screen then you can notice the difference however if you are at a normal viewing distance you simply cannot notice the pixel loss...because the image is small to begin with.....I cant tell the difference between full screen 1080p on a 25" monitor and 6 cameras in a matrix at normal viewing distances because while you lose pixels the image gets smaller....that is why a cell phones image looks great even though its a low res substream...We can agree to disagree
