- May 6, 2017
- 4,209
- 7,096
I'd like to have one of my cams pull back to a wider view during the day, then pull back in to a tighter view at night.
Is there any way to invoke a preset PTZ position on a schedule?
I can change profiles and the motion detection zones within with the schedule but don't see any way to change the PTZ position within profiles or otherwise.
Edit to add:
I'd originally said that there was no option to do it on this cam directly but there does appear to be so I can use that. I'd still like to know if there's a way to do this in BI.
Thanks.
Edit to add:
Thanks.
