You can see my network configuration below. Basically, all my POE cams are sitting on a separate NIC behind the BI server (green). The BI server has a NIC on the front end to connect to the router of the home network side (red).
(1) I take it there is no easy way to add WiFi capability to my BI server using a WiFi USB dongle then allowing a WiFi cam to directly connect via WiFi to the BI server?
(2) I take it that it might be better to connect the WiFi cam directly to my WiFi router then have the BI server talk to it from the home network side?
