- Mar 4, 2018
- 54
- 4
I downloaded the trial version of express+, and have to say, I'm pretty impressed with it. HW acceleration works fantastic compared to BI, even when using the intel integrated version, plus it has the option for NVidia acceleration. Other than that, to those that have experience with xprotect, what are its advantages over BI?
Other than the significant difference in hardware acceleration, the interface feels familiar to BI, but the learning curve on this is pretty steep... I don't want to spend the significant money on this if all it gives me is less cpu usage. The main thing I've found lacking in BI is the clip timeline.. it has no image rec, can't tell me what it detected (like sighthound-- detects whether movement is from a person or a car or whatever).
Anyway, would appreciate any thoughts from people who have actually used it, and comparisons to BI.
Obviously I'm aware of the massive cost differential.
