Any reviews of TP-Link Vigi NVR and Vigi Cameras?
CasualUser
Jan 22, 2024
2
1
India
These reviews are scarce and very rare to find. All I could find on youtube were very scripted videos probably TP-Link sponsored.
Anyone using these? Would you recommend this over Hikvision?
I am just this close to purchasing their NVR 10008H and couple of Vigi 340 cameras.
Much appreciated, thanks.
Be advised that the 4MP camera specs indicate it has a 1/3" sensor which is too small for good night time performance. It might show still images OK with IR or its white LED but motion will likely be blurred. A 4MP camera should have a sensor no smaller than 1/1.8".
Reactions: CasualUser
Thank you so much for letting me know this. As you can tell, I'm as green as grass when it comes to these things. Can you please suggest me a good alternative for night time? Doesn't have to be within the TP-Link ecosystem.
Reactions: TonyR
I can confirm that. Daylight images are fine but night time images have blurried moving objects. Even when I stood under the camera and the camera used white light (not just IR), my face was very grainy and noisy as hell.
Guess we can't expect much for this price.
Reactions: TonyR
Just did a quick test - this is what it looks like.
I was literally a meter away from the camera. Blurried images when I walked/moved, when I was still - it was Okay-ish.
P.S. The camera is VIGI C250
Yeah, that guy looks pretty suspicious, IMO....:winktongue:
Thanks for the images, they confirm what many have found out, often after an uninformed purchase: a sensor that is under-sized for the amount of pixels it is paired with requires that the shutter be slowed down to provide enough light (visible or IR) to produce a decent image......and when there's motion, that shutter is not fast enough to NOT prevent blur......no motion, not too bad. Speed up that shutter to prevent motion blur then there's not enough light.
And generally paired with that better image size to resolution (megapixels) ratio is a higher cost. The old "you get what you pay for" adage.
Reactions: looney2ns
Uniview tend to be expensive in Australia.
Especially the 4mp ones with the correct mp sensor ratio (which are also not easy to find).
Their uniarch brand are cheaper but I don't think any of them have the right mp sensor ratio.
If you want a cheaper camera you'll probably need to look at 2mp models.
Reactions: TonyR
