At the moment I am not using direct to disk recording or recording the sub stream continuously, just recording trigger events which is working fine so far.
All cameras are recording continuously to 128g cards so if something is missed I could go directly to the camera. This makes it light for my I5-6500 to run 8 cameras at 10% cpu.
The only anomaly I have seen is sometimes a vehicle will trigger a camera and after a few seconds it will disappear and reappear 60 feet down the road. But, when you use the scrubber to scroll through the clip it is there all the way through the clip. Almost like the sub stream recorded it but the main stream had a hiccup.
Any issues with this approach or suggestions.
Getting there.....
Thank you...
Getting there.....
Thank you...
