Any input on upgrading to IPC-Color4K-B180 from the T180?
marklyn
Pulling my weight
Jun 13, 2015
522
142
I currently have an IPC-Color4K-T180 that I don't think I'm going to be able to revive after a failed FW update.
If I have to replace it, should I pay a bit more $ and get the IPC-Color4K-B180 instead? My primary goal is catching small animal triggers at a 40' distance and based on what I've read on the B180, it might do a better job than the T180.
Or, recommendations for another 180 degree camera brand, but wanting to keep under $300.
T180 is a turret form factor. B180 is a bullet form factor.
Both are the same camera but different form factors.
Reactions: TonyR
oh, thanks. I knew about the physical difference but thought the B180 was newer or better. Thanks
