F Fraenzi n3wb Aug 19, 2022 3 1 Germany Mar 31, 2023 #1 Hello, How can I open the housing of a camera AR-W260. Water has probably gotten into the connection cable. Thanks very much
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,549 51,166 Alabama Mar 31, 2023 #2 Fraenzi said: Water has probably gotten into the connection cable. Click to expand... Does the male-to-female RJ-45 connection show signs of water ingress and corrosion? I ask because if it does, I would address that before opening the camera itself, as that can present a new issue if water has not entered the camera.
F Fraenzi n3wb Aug 19, 2022 3 1 Germany Mar 31, 2023 #3 TonyR said: Does the male-to-female RJ-45 connection show signs of water ingress and corrosion? Click to expand... Thanks no, everything looks good on the plug. I ask because if it does, I would address that before opening the camera itself, as that can present a new issue if water has not entered the camera. Click to expand... the water is probably getting in at the cable entry into the housing Attachments IMG_20230331_130026.jpg 9.1 MB · Views: 6 Reactions: TonyR
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 21,549 51,166 Alabama Mar 31, 2023 #4 Fraenzi said: Thanks no, everything looks good on the plug. the water is probably getting in at the cable entry into the housing Click to expand... VERY possible...which is why it's the last bullet in my post regarding waterproofing the pigtail and the connections here.
F Fraenzi n3wb Aug 19, 2022 3 1 Germany Apr 1, 2023 #5 TonyR said: VERY possible...which is why it's the last bullet in my post regarding waterproofing the pigtail and the connections here. Click to expand... thank you very good tip but how do I get the case of the camera open
