Hi to all,
After I update the firmware of a Anran AR-24NB-IP this camera only partial funtion afterwards.
It works very slow when login to web-if and no video anymore only black video window.
Also it display two available video channels I never had that before.
I downloaded the firmware 00001532 = IPC_HI3516C_53H20L
As 1532 was what I saw when I checked the camera current version.
This is the firmware I flashed:
General_HZXM__IPC_HI3516C_53H20L_RT3070_V4.02.R11.Nat.OnvifS.20160615_ALL.bin
Now at the moment I even have no web-if access anymore, don't now why.
At the serial output I see the the board is bootting two or sometimes three times but no response at port 80 or 34567, only TCP port 9527 is available.
Can I somehow reflash or repair the firmware with the bootloader?
The firmware contains these files:
Any help is welcome.
		Code:
	U-Boot 2010.06-svn (Oct 14 2015 - 15:02:08)
DRAM:  256 MiB
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC2 0x20 0x18 0xC2 0x20 0x18
Spi(cs1): Block:64KB Chip:16MB Name:"MX25L128"
envcrc 0xc9686887
ENV_SIZE = 0x3fffc
In:    serial
Out:   serial
Err:   serial
Press Ctrl+C to stop autoboot
CFG_BOOT_ADDR:0x58080000
16384 KiB hi_sfc at 0:0 is now current device
### boot load complete: 1973968 bytes loaded to 0x82000000
### SAVE TO 80008000 !
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   linux
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1973904 Bytes = 1.9 MiB
   Load Address: 80008000
   Entry Point:  80008000
load=0x80008000,_bss_end=80829860,image_end=801e9e90,boot_sp=80797168
   Loading Kernel Image ... OK
OK
Starting kernel ...
		Code:
	Install
u-boot.bin.img
u-boot.env.img
web-x.cramfs.img
custom-x.cramfs.img
user-x.cramfs.img
romfs-x.cramfs.img
InstallDesc
