Anpviz UltraHD 4K (8MP) Outdoor Security IP Turret PoE Camera with Microphone/ Audio,3840x2160, 100ft NightVision, 2.8mm Wide Angle , IP67 Weatherproof, MicroSD Recording (256GB),Hikvision Compatible
Amazon Prime $89.99
I like it's performance in all categories, ...but that is now, after 6 hours of use in Blue Iris.
I also liked the price. $89.99
But...
I did not like that the documentation sends you to a broken link.
I did not like that after getting to their main website, I had to jump through hoops to find the 'sadp' tool.
I did not like that after downloading their 'sadp' tool, it would not install due to errors; tried 4 times.
I did not like that I had to search through multiple old hard drives to find one that worked.
If you are experienced in the use and installation of IP cameras, this one, if it stays working, is a clear winner.
* above here is what my review on Amazon says. *
The problems that inexperienced buyers (on Amazon) will face requires an experienced helper.
I doubt that a company with so many obstacles to their products can survive.
Amazon Prime $89.99
But...
