I appreciate all the help. Sorry for the initial confusion. Doesn't appear that this is just a BI issue. Though the OpenVPN Connect app indicates that it is connected, I'm not actually able to get onto the LAN. Don't know a lot about this, but could it be a firewall issue? The Incoming log on the router is blank. Here is the log for Open VPN iOS:
2016-11-07 18:50:10 EVENT: RESOLVE
2016-11-07 18:50:11 Contacting
xx.xxx.x.xx:1194 via TCP
2016-11-07 18:50:11 EVENT: WAIT
2016-11-07 18:50:11 SetTunnelSocket returned 1
2016-11-07 18:50:11 Connecting to [
xxxx.gotdns.org]:1194 (xx.xxx.x.xx) via TCPv4
2016-11-07 18:50:11 EVENT: CONNECTING
2016-11-07 18:50:11 Tunnel Options:V4,dev-type tun,link-mtu 6043,tun-mtu 6000,proto TCPv4_CLIENT,cipher BF-CBC,auth SHA1,keysize 128,key-method 2,tls-client
2016-11-07 18:50:11 Creds: Username/Password
2016-11-07 18:50:11 Peer Info:
IV_GUI_VER=net.openvpn.connect.ios 1.0.7-199
IV_VER=3.0.11
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
2016-11-07 18:50:11 NET Internet:ReachableViaWWAN/WR t------
2016-11-07 18:50:11 NET WiFi:NotReachable/WR t------
2016-11-07 18:50:12 VERIFY OK: depth=1
cert. version : 3
serial number : B1:5D:95:C0:46:40
B:05
issuer name : C=US, ST=CA, L=Irvine, O=Linksys, OU=Linksys, CN=linksys, ??=changeme,
[email protected]
subject name : C=US, ST=CA, L=Irvine, O=Linksys, OU=Linksys, CN=linksys, ??=changeme,
[email protected]
issued on : 2013-12-03 19:06:03
expires on : 2023-12-01 19:06:03
signed using : RSA with SHA1
RSA key size : 1024 bits
basic constraints : CA=true
2016-11-07 18:50:12 VERIFY OK: depth=0
cert. version : 3
serial number : 01
[email protected]
subject name : C=US, ST=CA, L=Irvine, O=Belkin, OU=Linksys, CN=localhost, ??=changeme,
[email protected]
issued on : 2013-12-03 19:08:25
expires on : 2023-12-01 19:08:25
basic constraints : CA=false
cert. type : SSL Server
key usage : Digital Signature, Key Encipherment
ext key usage : TLS Web Server Authentication
2016-11-07 18:50:13 SSL Handshake: TLSv1.0/TLS-DHE-RSA-WITH-3DES-EDE-CBC-SHA
2016-11-07 18:50:13 Session is ACTIVE
2016-11-07 18:50:13 EVENT: GET_CONFIG
2016-11-07 18:50:13 Sending PUSH_REQUEST to server...
2016-11-07 18:50:13 OPTIONS:
0 [topology] [subnet]
1 [route-gateway] [xxx.xx.13.1]
2 [route] [192.168.1.0] [255.255.255.0]
3 [ping] [10]
4 [ping-restart] [120]
5 [ifconfig] [xxx.xx.13.2] [255.255.255.0]
2016-11-07 18:50:13 PROTOCOL OPTIONS:
cipher: BF-CBC
digest: SHA1
compress: NONE
peer ID: -1
2016-11-07 18:50:13 EVENT: ASSIGN_IP
2016-11-07 18:50:13 Connected via tun
2016-11-07 18:50:13 EVENT: CONNECTED
[email protected]@
xxxxxx.gotdns.org:1194 (xx.xxx.5.xx) via /TCPv4 on tun/
xxx.xx.13.2/
2016-11-07 18:50:13 SetStatus Connected
