I haven't had any luck finding this thread but I'm sure it must exist.
I have a half dozen cameras, some of them are PTZ that I keep on sentry duty where they pan to a position, wait for 30 seconds, pan to another position, wait 30 seconds, pan to the last position wait 30 seconds and repeat the pattern in the opposite direction.
My problem is that at on a couple of these cameras I have vehicles parked in frame, so when it pans to that location it detects motion (from the pan) then it detects a vehicle (that wasn't there moments ago because it was looking elsewhere) and then it pans back causing more motion.
I see there are a few different places to affect what I am doing, disable PTZ causing motion events doesn't seem to be fixing the problem, adding additional confirmation pictures are not fixing the problem.
I can't figure out how to get the Periodic Analysis to flag objects to ignore in frame, I can get it to identify the objects I want to ignore when the camera is looking, but I can't figure out the combination of buttons and zones (which I don't use) to fix this.
Is there a thread describing this exact problem so someone doesn't have to type out the whole solution?
Any help appreciated.
Thanks,
Thanks,
