I purchased an IPC-HFW5241E-Z12E to add to my currently installed and functional Lorex cameras. All are connected to my Lorex 6108 NVR via an external switch. When I connected the Z12 to the switch, I went through the process of adding the camera. When added, it gave me the red status light. So I gave it a while and it never connected. I tried to go into the camera’s setting with the default IP address. I answered the first couple of questions and the got to the log in screen. This is where I hit another road block. None of the passwords would work(admin, pass, adminip, etc…) I reached out to Andy and told me to use the config tool. I was able to find the camera, change the camera’s password, initialize, change the IP address to an unused but similar to my other cameras and able to view the Z12 within the config tool. Assuming everything was good at this point, I went back to the NVR to add the camera again. I see the new IP address but still get the same red status. I went in to change the port to the same ports the other cameras(37777 to 35000). Still nothing. Any help would be appreciated. Thanks!
