Annke WPT400 (I81CK) RTSP URL
bernd0815
Jul 19, 2023
4
Germany
Hello,
I bought an Annke WPT400 (I81CK) IP Camera. The camera itself is working fine but I try to connect it to shinobi.
Shinobi finds the camera asks for ONVIF info and gets the info back.
My problem is that the RTSP URL provided via ONVIF is only valid for some minutes and changes constantly. The URL looks like that: rtsp:/192.168.178.227:554/live/1jfiegbr2xxx_p0_AJPHMGHLCGVR
Is there a possibility to find out the correct, steady stream URL? Or is there a possibility to make shinobi request the new URL constantly?
Kind regards,
Bernd
Assuming ONVIF has been enabled in the cam:
  • Install ODM, open it, find your camera in the left column, click on it and log in with the cam's username and password.
  • In the 2nd white column from the left find "Live Video" and click on it.
  • If you get live video OK on the right, note the URL at bottom right of screen.
Hi,
yes, your assumption is correct. ONVIF is enabled. Unfortunately i try to find a download source for ODM since yesterday in the evening. The download on SourceForce is disabled. Is there any other source?
Kind regards,
Ok. After I posted my reply I found a source that was not availiable yesterday.
When I press on "LIveVideo" everytime the URL changes.
rtsp:/192.168.178.227:554/live/1jfiegbr2xxxx_p0_IOQILFZHYSIC
rtsp:/192.168.178.227:554/live/1jfiegbr2xxxx_p0_FPIYMWUFDFLA
rtsp:/192.168.178.227:554/live/1jfiegbr2xxxx_p0_POZXCQHNXJWV
But somehow it must be possible to get a constant stream from the camera because the chinese app (Myannke) also gets a constant string...
Kind regards,
Bernd
same here, I'm able to get a few seconds of video and then I find that the path has changed.. so this explains why we cant just stream from VLC and we need a special plugin.
If anyone found a workaround I'd appreciate!
Kind regards,
Bernd
did you find the correct rtsp address? I'm trying to add this camera to the NVR via rtsp because ONIF is not supported by this camera
May be too little, too late but, I got the Onvif to work. I did it thru mipc, factory reset the camera and added it to mipc and there it was right where it is supposed to be.
