Annke I51DM Looking for Stream infos
emersonvier
Apr 29, 2017
116
38
IL
Hi all, I looking Stream, infos for Annke I51DM.
Have you tried querying the camera with ONVIF Device Manager?
The RTSP stream info is shown at the bottom of the Live Video page.
If the cam is ONVIF compatible, then in Blue Iris you should be able to put in the cam's IP address, username and password then click on "Find/Inspect" and it will populate the stream URLs automatically....at least the "Main" stream anyway.
If no joy, find the main stream with ODM as indicated by @alastairstevenson and type it in manually in the yellow highlighted area to the right of the "Main" stream (default) and click on "OK". If that works OK then the substream can be derived from that URL as well.
Reactions: emersonvier
When I click "find/inspect" I got this below
By ONVIF Device Manager, I can see this camera on the Device List.
On Annke website showed this camera is ONVIF compatible.
Is a first time I use the software I only can see this
Can you confirm these were found automatically as opposed to you adding the IP address?
That's the normal mode of operation.
Click the entry that you want to look at.
If the logon credentials are correct, you will see a wealth of info about the selected device, including Live Video.
Reactions: TonyR
