Hi all. I've recently had a warranty replacement of my Annke C800 camera and now have a small issue with the video feed pausing/flashing black every few seconds. I'm pretty sure the old camera wasn't doing it.
See sample here
The effect is also present at night, and much worse if I enable WDR, and sometimes activates the motion recording because of the glitch.
I get the same issue whether viewing the live feed from IE/Chrome/iVMS, or viewing the recording, which is done to the internal micro SD card. So I don't believe it to be a bandwidth OR storage issue.
My relevant settings are below:-
Camera
Annke C800 (I91BM) (Hikvision clone)
Firmware: V5.5.102 build 210611
Integration Protocol
ONVIF: OFF
Video/Audio
Resolution: 3840x2160
Bitrate: Constant
Video quality: highest
Frame rate: 12
Max bitrate: 8192
Video encoding: H.265+
I-frame: 12
SVC: OFF
Image Adjustment
Brightness, Contrast, Saturation, Sharpness all 50
Exposure Settings
Iris: Manual; Exposure: 1/100
Day/Night Switch
Day/Night Switch: Auto; Sensitivity: 5
Filtering Time: 5
Smart Supplement Light: OFF
Supplement Light Mode: IRlight Supplement Light
Light Brightness Control: Auto
IR Light: 100
Backlight Settings
BLCArea, WDC, HLC: OFF
Image enhancement
DNR: OFF
Video Adjustment
Mirror: OFF
Video standard: PAL 50Hz
Motion Detection
Enable Motion Detection & Enable Dynamic Analysis: ON
I've tried different bitrates, even the lowest, and resetting to factory defaults. Tried different i-frame values. Any changes either make it worse or no difference.
Any ideas? As the camera is new I'm trying to find out if it might be a hardware issue and needs replacing.
See sample here
Camera
ONVIF: OFF
Video/Audio
Bitrate: Constant
Frame rate: 12
Max bitrate: 8192
I-frame: 12
SVC: OFF
Image Adjustment
Exposure Settings
Day/Night Switch
Filtering Time: 5
IR Light: 100
Backlight Settings
Image enhancement
DNR: OFF
Video Adjustment
Mirror: OFF
Motion Detection
