Hi all.
Hoping someone can assist me with this.
I have an Annke C500 turret camera when I attempt to do an output via Rtsp to vlc etc it appears to have quite a bit of lag anything 2-30 seconds.
I thought it might be the config settings so I changed the port to 100mb full duplex and reduced everything down to 1080p 15 fps although the same problem remains.
The crazy thing is if I am to use Annke Vision live view on the iPhone there is little to no latency, even at 3k quality, the home network is all cat 6 cables all copper none of the aluminium caper.
I ran an internal speed check the routers are pulling 900+ mb without an issue. The internal speed is basically on the 1gbit.
On VLC I did change a few settings to no avail, this is running through a formuler z8 box, it will be used for live streaming internally.
Just wondering if there is something more sinister going on, would appreciate any thoughts or suggestions.
