Android tablet as front door cam viewer
ml2000id
Sep 13, 2015
19
2
Hi, I am trying to setup an old android tablet to stream my front door cam and hanging it inside the house right next to the door.
The web ui should be fine for streaming, but I would like to prevent screen burn in by only waking up the screen when there is an alert triggered (eg. Someone approaching the front door) by BI. I see that BI has quite a few options like running a script when there is an alert.
Thinking of doing it using Tasker or the likes. Tried looking in this forum if anybody has done something similar. Any leads or inputs?
Thanks.
Sent from my SM-N770F using Tapatalk
Or just leave the screen on showing BI's auto-cycle for a group of cams (or all cams). it'll automatcally prioritze the cam(s) with action, and there should be enough variation in the views to prevent burn-in...
Thanks Jaydeel, your work definitely inspired me. I did not consider installing BI app on the tablet previously. I was almost able to do what I wanted with just BI app and tasker.
Unfortunately my tablet is old enough to not support BI app. (Kitkat!)
Will be trying the MQTT route, running the server (broker) on my BI machine and getting BI on the PC to publish MQTT messages on alerts. Then running a tasker MQTT subscriber plugin on the tablet.
Will give an update
