If you're into command-line stuff and going to use ffmpeg to convert the cache of still frames into video, you can get it to skip frames if there are going to be too many for the level of change you'll be seeing. So too many gives you some flexibility depending on how fast it grows.What is a good time lapse time interval? Every 4 hours? Every 6 hours? I am thinking first frost is usually end of October so 2 or 3 months worth.
Actually won a lot of rain Bird 2-in 1800 series PRS x20 for around $20. Didn't realize I actually need four or six inch but oh well if these oscillating sprinklers don't pan out I am thinking of doing what you are thinking of with ground stakes. Already have items in my Amazon cart ready. Just remember to get the male to male connector which I actually could not find on Amazon. Rainbird has the connector for $7 each which is outrageous for piece of plastic. I will return home to find alternative connectors. And I believe since I have the sprinkler heads themselves I still need to purchase the VAN tips or whatever they are called that determines the spray patternI'm always looking for better sprinklers. I just ordered, and haven't yet set up, a RainBird 32SA, that's actually built for in-ground systems. It has a 1/2" NPT female fitting on the bottom. I'll mount that on a piece of 1/2"x24" PVC with a ground stake, and hose fittings, and use it as a portable. It'll cover out to about 32 feet in a 40-360 degree pattern and the spray can be adjusted as well. I'm using a four zone hose timer, with BlueTooth from Eden. I've been using Orbit gear driven sprinklers but can't run two off of one hose, 3/4" hose, because each one puts out too much water dropping the pressure too much.
I have a large drip system for use in the garden and it really works well there, but we don't bother with a garden anymore. Just a few tomato plants.
I thought they had to be male ends. Not female.A male to male is a coupler, like this in a package of five-
yep, some items came in that will work. I have 20 of these pop ups, 20 of these stakes. Now, to chop up some hose to interconnect them.Then it's a simple male coupling, again a five pack -
I use these on both ends of a precut 1/2"x24" piece of PVC from Lowes. That 24" expands the pattern a bit, like about six feet or more.
I'm no longer interested in the time lapse of the grass.what a fun little DIY project. Originally, I was planning to use garden hoses to interconnect everything. But found out 3/4" x 100' hose was $80+ each. And I would need 300'. So 3/4" poly-pipe 100PSI it is at Lowe's for $33x100'. This is temp for this year only. Next spring, I plan on using 160+PSI polypipe or PEX pipe for underground system. I sure did learn alot about this sprinkler system engineeringEven bought a flow meter that I have to eventually hook up to the RainMachine (incase of blown/leaky polypipe or something) so it can shut off the main irrigation line via main valve.
I had to build my own 8 zone manifold, which includes easy removal compression fittings in case valve fails. I think 8 zone manifold for DIY parts came in around $200. Retail if bought manufactured would of been 2 or 3x's that.
The manifold is sitting in a temporary spot, all held down stoutly with tie wraps. Again, this is temp for the next couple months. I'll remove it all, drain, and store it all away come freezing time.
These are Rainbird 2" PRS 1800 series pop up sprinklers. Why did I go 2"? Cause I bought 16 of them new in the box at local auction for $20I'll swap out to 4" versions next year.
And so came time to re-purpose some older 5231's. And setting up Blue Iris with scheduling (global over ride and made own specific schedules) to snap 1 picture every hour from 6am to 6pm 7 days a week.
Once again, at local auction...I snagged a pair of photography tripods for $5. I self screw tapped the 5231 bases to the aluminum tripods and set them out. Will find out how 40-50mph winds will affect these tripods soon
View attachment 140242View attachment 140243
The big problem is a controller that's big enough to handle that many zones, or more. I may fool with timed events in HomeSeer and see how that goes.
Alternatively - if you want to keep your options open because you don't know until you process it what the video is going to look like - you can over-provision the number of frames (ie a shorter timelapse interval) and define the input framerate when you create the video, automatically discarding the excess.Once you know how long you want your final clip to be, then it's simple math to determine the image interval .
