Wow, I step away from the interwebs for a while and get all this advice. Thanks, everyone!
I ended up changing the install location. The corner I was going to use turned out to have too many other logistical issues, so my wife caved on letting me use my original choice - part of an existing convenient closet. The closet is in the same room but backs right up to the attic in a more centralized location.
I fastened a couple pieces of plywood to the wall and installed an open frame 19" rack on the wall. I used 2" PVC electrical conduit to punch several paths through the plywood/sheetrock/insulation into the attic.
I still need to work out proper ventilation for the closet - just leaving the closet open for now. I have a couple large switches, my NAS, a server, and a few other heat generating widgets in there. I have an HVAC guy coming next week to give me some options.
On the plus side, I got my first three Duhau IPC-HDW5231R-Z cameras installed and running on this system!
