We have an existing 8 camera system with a DVR installed to cover multiple properties on acreage.
Cameras are located many hundreds of feet apart from the DVR, and use passive baluns on each end to send each video signal over a single pair in underground CAT5 cables that carry multiple camera feeds.
For the furthest distance cameras, there are extra, unused coax cables I can use. For some others, there are empty conduits I can use, and for some, I may have to pull new coax to replace the CAT5.
I want to upgrade to 10 or 11 IP cameras, and probably use multiple Highwire pairs to push the camera feeds over the longer distances.
Power is available for locally sourced PoE near the furthest distance cameras. All camera feeds run to the shop building, and then on to the main house where the NVR will reside.
The shop has a LAN connection to the main house and spare CAT5 and coax cables to the main house as well.
Here's one possible layout. Will it work? Are there better options?
