I recently installed a 2nd Amcrest IP2m-842 camera and set it up in Blue Iris. I am getting very bad ghosting effects as seen in the upload.
Settings are:
Frame Rate: 15fps
I-Frame: 15fps
3D NR: Off
Encode: H.264H
Resolution: 1080P
Bit Rate Type: CBR
Bit Rate: 4096
Direct to Disk Recording enabled
Settings are:
Frame Rate: 15fps
I-Frame: 15fps
3D NR: Off
Encode: H.264H
Resolution: 1080P
Bit Rate Type: CBR
Bit Rate: 4096
