Amcrest camera video with embedded timecode?
TheWaterbug
Getting comfortable
Joined
Oct 20, 2017
Messages
845
Reaction score
1,787
Location
Palos Verdes
I have an Amcrest IP5M-T1179EW-28MM and an IP5M-B1186EW-28MM watching my trail for wildlife, and I like to take the motion captures and assemble them "2-Up" like this, to show the action:
Right now I'm doing the assemblage in DaVinci Resolve, which is super powerful software, and free!
But the two cameras trigger at different times, because they're pointing in opposite directions, and aligning the two videos in time is tedious. Resolve has an option to Align Clips: Automatically by Timecode, which I'd like to use, but the mp4s that I download from the cameras via Amcrest Video Surveillance Pro do not contain embedded timecode, as far as I can tell. I can't use the Align Clips: Automatically by [audio] Waveform, because the B1186EW doesn't have a mic.
Please note that I'm not talking about the burned-in "time stamp" in the corner of the video; I'm talking about true binary timecodes embedded as a data in the video stream, that can be interpreted by software to determine exactly when a frame was recorded.
Do any of the export options from Amcrest cameras include timecode? And are those formats importable in Resolve?
Thanks!
jack7
Getting comfortable
Joined
Mar 21, 2019
Messages
323
Reaction score
250
Location
USA
Perhaps you could try this:
Record Regular records along with Motion Detect records using an Amcrest NVR or the PC-NVR feature of Amcrest Surveillance Pro. Then you could export a clip from each camera's recordings with the same start/stop times to get Davinci input mp4 files.
TheWaterbug
Getting comfortable
Joined
Oct 20, 2017
Messages
845
Reaction score
1,787
Location
Palos Verdes
Unfortunately that doesn't work because they'll trigger on motion at different times. As the coyote comes running downhill, he'll trigger the TrailUp camera first, and then when crosses over, the TrailUp will end the event, and the TrailDown will trigger.
When I assemble the footage I want both cameras to show from the time he arrives on the first camera to when he departs the second camera.
I now have two cameras with mics on this trail, so about 50% of the time I can Align by Waveform, but if there isn't much sound, or if there's wind noise, then it won't work.
Does any native IP camera video format embed true binary timecode?
Top
