Amcrest and Dahus wall mounts.
Elgato54
Dec 14, 2019
70
13
Arizona
Has anyone used both the Amcrest and Dahua wall mounts? (203W) Are they pretty much the same?
Thanks
Thanks
Hi @Elgato54
Amcrest carries Dahua OEM IP cameras - so the junction boxes and wall mounts will also be Dahua OEM.
( just double check the specs if the model numbers are not clear )
Lorex also mostly carries Dahua OEM, as does Montavue and others - so you can often find various other vendors which have Dahua OEM junction boxes and mounts.
