Hello,
I'm back with a few more questions. I was able to setup my hikvision cubes to use the pir with blue iris. I didn't find this in any of the guides but my cams have a tab called "other alarm" where you had to check a box to activate the pir first.
This has me wondering if there is any other way to use on board motion with other cams? Maybe this wouldn't work well at all but if BI could poll a directory somewhere that your cams are dumping snapshots ... Could this in theory signal BI to record and then stop again once the snap shots no longer show up? Not sure what kind of delay this would cause in recording. I'm running 6 cams on an a-10 with 35% cpu usage somehow. I should really upgrade my machine now that I've added cams.
I was also wondering where do you find the help file? It always says something like not found or cant access the server when I try and open in BI.
thanks
thanks
