ALPR OCR not working
Spooling
Sep 26, 2015
216
58
Hey there;
I'm just starting to get BI ALPR working and I'm wondering why it's not listing the characters for the license plates. It shows dayplate or nightplate properly, but there are no actual letters logged or anything.
I'm running License Plate Reader 3.3.4 and Yolo 6.2
Any help would be appreciated. Ultimately I'm working towards getting algertc's full database system going.
Hey there;
Do you have the "On Alert" portion filled out?
Here's the install.log
2025-12-06 09:23:38: Installing CodeProject.AI Analysis Module
2025-12-06 09:23:38: ======================================================================
2025-12-06 09:23:38: CodeProject.AI Installer
2025-12-06 09:23:39: 311.7Gb of 475Gb available on (No label) (Windows 11 x86_64 - windows)
2025-12-06 09:23:39: General CodeProject.AI setup
2025-12-06 09:23:39: Checking for VC++ Redist...v14 Present.
2025-12-06 09:23:41: Creating Directories...done
2025-12-06 09:23:41: GPU support
2025-12-06 09:23:41: CUDA Present...No
2025-12-06 09:23:41: ROCm Present...No
2025-12-06 09:23:41: Checking for .NET 9.0...Checking runtimes...All good. Found .NET aspnetcore 9
2025-12-06 09:23:42: Reading ALPR settings.......done
2025-12-06 09:23:42: Installing module License Plate Reader 3.3.4 (Internal)
2025-12-06 09:23:42: Installing Python 3.9
2025-12-06 09:23:44: Downloading Python 3.9 interpreter...Expanding...done.
2025-12-06 09:23:49: Creating Virtual Environment (Local)...done
2025-12-06 09:23:49: Confirming we have Python 3.9 in our virtual environment...present
2025-12-06 09:23:50: Downloading ALPR models...Expanding...done.
2025-12-06 09:23:50: Copying contents of ocr-en-pp_ocrv4-paddle.zip to paddleocr...done
2025-12-06 09:23:51: Checking CPU compatibility...All good
2025-12-06 09:23:51: Installing Python packages for License Plate Reader
2025-12-06 09:23:51: [0;Installing GPU-enabled libraries: If available
2025-12-06 09:23:52: Ensuring Python package manager (pip) is installed...done
2025-12-06 09:23:55: Ensuring Python package manager (pip) is up to date...done
2025-12-06 09:23:55: Python packages specified by requirements.txt
2025-12-06 09:23:59: - Installing NumPy, a package for scientific computing...(✅ checked) done
2025-12-06 09:24:14: - Installing PaddelPaddle, the Deep Learning platform...(✅ checked) done
2025-12-06 09:24:47: - Installing PaddleOCR, the OCR toolkit based on PaddlePaddle...(✅ checked) done
2025-12-06 09:24:50: - Installing imutils, the image utilities library...(✅ checked) done
2025-12-06 09:24:50: - Installing OpenCV, the Computer Vision library for Python...Already installed
2025-12-06 09:24:57: - Installing the CodeProject.AI SDK...(✅ checked) done
2025-12-06 09:24:58: Scanning modulesettings for downloadable models...No models specified
2025-12-06 09:24:58: Executing post-install script for License Plate Reader
2025-12-06 09:24:58: Applying PaddleOCR patch
2025-12-06 09:24:58: 1 file(s) copied.
2025-12-06 09:25:09: INFO: Could not find files for the given pattern(s).
2025-12-06 09:25:09: C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\lib\site-packages\paddle\utils\cpp_extension\extension_utils.py:718: UserWarning: No ccache found. Please be aware that recompiling all source files may be required. You can download and install ccache from: 2025-12-06 09:25:09: warnings.warn(warning_message)
2025-12-06 09:25:14: Self test: Self-test passed
2025-12-06 09:25:14: Module setup time 00:01:33.12
2025-12-06 09:25:14: Setup complete
2025-12-06 09:25:14: Total setup time 00:01:36.23
Try uninstalling the License Plate Reader module then reinstall the module using Do not use download cache and Install verbosity Loud. After the install finishes run a test again to see if it works.
OK, I did that and it still doesn't work with the sample image (same results)
Here's the new install.log
2025-12-07 16:53:15: Installing CodeProject.AI Analysis Module
2025-12-07 16:53:15: ======================================================================
2025-12-07 16:53:15: CodeProject.AI Installer
2025-12-07 16:53:16: ======================================================================
2025-12-07 16:53:16: 306.7Gb of 475Gb available on (No label) (Windows 11 x86_64 - windows)
2025-12-07 16:53:16: General CodeProject.AI setup
2025-12-07 16:53:17: Checking for VC++ Redist...v14 Present.
2025-12-07 16:53:19: Creating Directories...done
2025-12-07 16:53:19: os, name, arch = windows Windows 11 (25H2) x86_64
2025-12-07 16:53:19: systemName, platform = Windows, windows
2025-12-07 16:53:19: edgeDevice =
2025-12-07 16:53:19: setupMode = SetupModule
2025-12-07 16:53:19: executionEnvironment = Production
2025-12-07 16:53:19: rootDirPath = C:\Program Files\CodeProject\AI
2025-12-07 16:53:19: appRootDirPath = C:\Program Files\CodeProject\AI\
2025-12-07 16:53:19: setupScriptDirPath = C:\Program Files\CodeProject\AI\
2025-12-07 16:53:19: utilsScriptsDirPath = C:\Program Files\CodeProject\AI\\scripts
2025-12-07 16:53:19: runtimesDirPath = C:\Program Files\CodeProject\AI\runtimes
2025-12-07 16:53:19: modulesDirPath = C:\Program Files\CodeProject\AI\modules
2025-12-07 16:53:19: externalModulesDirPath = C:\Program Files\CodeProject\AI\..\CodeProject.AI-Modules
2025-12-07 16:53:19: modelsDirPath = C:\Program Files\CodeProject\AI\models
2025-12-07 16:53:19: downloadDirPath = C:\Program Files\CodeProject\AI\downloads
2025-12-07 16:53:19: downloadModuleAssetsDirPath = C:\Program Files\CodeProject\AI\downloads\modules\assets
2025-12-07 16:53:19: assetStorageUrl = 2025-12-07 16:53:19: GPU support
2025-12-07 16:53:19: CUDA Present...No
2025-12-07 16:53:19: ROCm Present...No
2025-12-07 16:53:19: Checking for .NET 9.0...Checking runtimes...All good. Found .NET aspnetcore 9
2025-12-07 16:53:19: Reading ALPR settingsUsed modulesettings.json to get value License Plate Reader
2025-12-07 16:53:20: .Used modulesettings.json to get value 3.3.4
2025-12-07 16:53:20: .Used modulesettings.windows.json to get value python3.9
2025-12-07 16:53:20: .Used modulesettings.json to get value Local
2025-12-07 16:53:20: .Used modulesettings.json to get value ALPR_adapter.py
2025-12-07 16:53:20: .Used modulesettings.windows.json to get value true
2025-12-07 16:53:21: .Used modulesettings.json to get value ["all","ǃwindows-arm64"]
2025-12-07 16:53:21: .done
2025-12-07 16:53:21: Installing module License Plate Reader 3.3.4 (Internal)
2025-12-07 16:53:21: Platform = windows, Platforms = ["all","ǃwindows-arm64"]
2025-12-07 16:53:21: Variable Dump
2025-12-07 16:53:21: moduleName = License Plate Reader
2025-12-07 16:53:21: moduleId = ALPR
2025-12-07 16:53:21: moduleVersion = 3.3.4
2025-12-07 16:53:21: runtime = python3.9
2025-12-07 16:53:21: runtimeLocation = Local
2025-12-07 16:53:21: installGPU = true
2025-12-07 16:53:21: pythonVersion = 3.9
2025-12-07 16:53:21: virtualEnvDirPath = C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv
2025-12-07 16:53:21: venvPythonCmdPath = C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Scripts\python.exe
2025-12-07 16:53:21: packagesDirPath = C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages
2025-12-07 16:53:21: moduleStartFilePath = ALPR_adapter.py
2025-12-07 16:53:21: Installing Python 3.9
2025-12-07 16:53:21: Installing python39 in C:\Program Files\CodeProject\AI\runtimes\bin\windows\python39
2025-12-07 16:53:21: Python 3.9 is already installed
2025-12-07 16:53:21: Creating Virtual Environment (Local)...Virtual Environment doesn't exist. Creating at C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv
2025-12-07 16:53:23: done
2025-12-07 16:53:23: Confirming we have Python 3.9 in our virtual environment...present
2025-12-07 16:53:23: Downloading ocr-en-pp_ocrv4-paddle.zip from to C:\Program Files\CodeProject\AI\downloads\modules\assets\ALPR
2025-12-07 16:53:23: Downloading ALPR models...Checking...
2025-12-07 16:53:23: already exists...Expanding...Heading to C:\Program Files\CodeProject\AI\downloads\modules\assets\ALPR
2025-12-07 16:53:23: Extracting ocr-en-pp_ocrv4-paddle.zip
2025-12-07 16:53:23: done.
2025-12-07 16:53:23: Copying contents of ocr-en-pp_ocrv4-paddle.zip to paddleocr...done
2025-12-07 16:53:25: Checking CPU compatibility...All good
2025-12-07 16:53:25: Installing Python packages for License Plate Reader
2025-12-07 16:53:25: [0;Installing GPU-enabled libraries: If available
2025-12-07 16:53:26: Ensuring Python package manager (pip) is installed...Looking in links: c:\Windows\TEMP\tmph3e0_n18
2025-12-07 16:53:26: Requirement already satisfied: setuptools in c:\program files\codeproject\ai\modules\alpr\bin\windows\python39\venv\lib\site-packages (56.0.0)
2025-12-07 16:53:26: Requirement already satisfied: pip in c:\program files\codeproject\ai\modules\alpr\bin\windows\python39\venv\lib\site-packages (21.1.3)
2025-12-07 16:53:26: done
2025-12-07 16:53:26: Ensuring Python package manager (pip) is up to date...Requirement already satisfied: setuptools in c:\program files\codeproject\ai\modules\alpr\bin\windows\python39\venv\lib\site-packages (56.0.0)
2025-12-07 16:53:26: Collecting setuptools
2025-12-07 16:53:26: Using cached setuptools-80.9.0-py3-none-any.whl (1.2 MB)
2025-12-07 16:53:26: Installing collected packages: setuptools
2025-12-07 16:53:26: Attempting uninstall: setuptools
2025-12-07 16:53:26: Found existing installation: setuptools 56.0.0
2025-12-07 16:53:26: Uninstalling setuptools-56.0.0:
2025-12-07 16:53:26: Successfully uninstalled setuptools-56.0.0
2025-12-07 16:53:27: Successfully installed setuptools-80.9.0
2025-12-07 16:53:27: WARNING: You are using pip version 21.1.3; however, version 25.3 is available.
2025-12-07 16:53:27: You should consider upgrading via the 'C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Scripts\python.exe -m pip install --upgrade pip' command.
2025-12-07 16:53:27: Requirement already satisfied: pip in c:\program files\codeproject\ai\modules\alpr\bin\windows\python39\venv\lib\site-packages (21.1.3)
2025-12-07 16:53:28: Collecting pip
2025-12-07 16:53:28: Using cached pip-25.3-py3-none-any.whl (1.8 MB)
2025-12-07 16:53:28: Installing collected packages: pip
2025-12-07 16:53:28: Attempting uninstall: pip
2025-12-07 16:53:28: Found existing installation: pip 21.1.3
2025-12-07 16:53:28: Uninstalling pip-21.1.3:
2025-12-07 16:53:28: Successfully uninstalled pip-21.1.3
2025-12-07 16:53:29: Successfully installed pip-25.3
2025-12-07 16:53:29: done
2025-12-07 16:53:29: Requirements Search Path is C:\Program Files\CodeProject\AI\modules\ALPR
2025-12-07 16:53:29: Searching for a suitable requirements.txt file in C:\Program Files\CodeProject\AI\modules\ALPR
2025-12-07 16:53:29: Python packages specified by requirements.txt
2025-12-07 16:53:29: Choosing Python packages from C:\Program Files\CodeProject\AI\modules\ALPR\requirements.txt
2025-12-07 16:53:29: - Installing NumPy, a package for scientific computing...Collecting numpy<2.0
2025-12-07 16:53:29: Using cached numpy-1.26.4-cp39-cp39-win_amd64.whl.metadata (61 kB)
2025-12-07 16:53:29: Using cached numpy-1.26.4-cp39-cp39-win_amd64.whl (15.8 MB)
2025-12-07 16:53:30: Installing collected packages: numpy
2025-12-07 16:53:31: Successfully installed numpy-1.26.4
2025-12-07 16:53:32: (✅ checked) done
2025-12-07 16:53:32: - Installing PaddelPaddle, the Deep Learning platform...Collecting paddlepaddle>=2.6.0
2025-12-07 16:53:32: Using cached paddlepaddle-3.2.2-cp39-cp39-win_amd64.whl.metadata (8.7 kB)
2025-12-07 16:53:32: Collecting httpx (from paddlepaddle>=2.6.0)
2025-12-07 16:53:32: Using cached httpx-0.28.1-py3-none-any.whl.metadata (7.1 kB)
2025-12-07 16:53:32: Collecting numpy>=1.21 (from paddlepaddle>=2.6.0)
2025-12-07 16:53:32: Using cached numpy-2.0.2-cp39-cp39-win_amd64.whl.metadata (59 kB)
2025-12-07 16:53:32: Collecting protobuf>=3.20.2 (from paddlepaddle>=2.6.0)
2025-12-07 16:53:32: Using cached protobuf-6.33.2-cp39-cp39-win_amd64.whl.metadata (593 bytes)
2025-12-07 16:53:33: Collecting Pillow (from paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached pillow-11.3.0-cp39-cp39-win_amd64.whl.metadata (9.2 kB)
2025-12-07 16:53:33: Collecting opt-einsum==3.3.0 (from paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached opt_einsum-3.3.0-py3-none-any.whl.metadata (6.5 kB)
2025-12-07 16:53:33: Collecting networkx (from paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached networkx-3.2.1-py3-none-any.whl.metadata (5.2 kB)
2025-12-07 16:53:33: Collecting typing-extensions (from paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached typing_extensions-4.15.0-py3-none-any.whl.metadata (3.3 kB)
2025-12-07 16:53:33: Collecting safetensors>=0.6.0 (from paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached safetensors-0.7.0-cp38-abi3-win_amd64.whl.metadata (4.2 kB)
2025-12-07 16:53:33: Collecting anyio (from httpx->paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached anyio-4.12.0-py3-none-any.whl.metadata (4.3 kB)
2025-12-07 16:53:33: Collecting certifi (from httpx->paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached certifi-2025.11.12-py3-none-any.whl.metadata (2.5 kB)
2025-12-07 16:53:33: Collecting httpcore==1.* (from httpx->paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached httpcore-1.0.9-py3-none-any.whl.metadata (21 kB)
2025-12-07 16:53:33: Collecting idna (from httpx->paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached idna-3.11-py3-none-any.whl.metadata (8.4 kB)
2025-12-07 16:53:33: Collecting h11>=0.16 (from httpcore==1.*->httpx->paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached h11-0.16.0-py3-none-any.whl.metadata (8.3 kB)
2025-12-07 16:53:33: Collecting exceptiongroup>=1.0.2 (from anyio->httpx->paddlepaddle>=2.6.0)
2025-12-07 16:53:33: Using cached exceptiongroup-1.3.1-py3-none-any.whl.metadata (6.7 kB)
2025-12-07 16:53:33: Using cached paddlepaddle-3.2.2-cp39-cp39-win_amd64.whl (101.6 MB)
2025-12-07 16:53:33: Using cached opt_einsum-3.3.0-py3-none-any.whl (65 kB)
2025-12-07 16:53:33: Using cached numpy-2.0.2-cp39-cp39-win_amd64.whl (15.9 MB)
2025-12-07 16:53:33: Using cached protobuf-6.33.2-cp39-cp39-win_amd64.whl (436 kB)
2025-12-07 16:53:33: Using cached safetensors-0.7.0-cp38-abi3-win_amd64.whl (341 kB)
2025-12-07 16:53:33: Using cached httpx-0.28.1-py3-none-any.whl (73 kB)
2025-12-07 16:53:33: Using cached httpcore-1.0.9-py3-none-any.whl (78 kB)
2025-12-07 16:53:33: Using cached h11-0.16.0-py3-none-any.whl (37 kB)
2025-12-07 16:53:33: Using cached anyio-4.12.0-py3-none-any.whl (113 kB)
2025-12-07 16:53:33: Using cached exceptiongroup-1.3.1-py3-none-any.whl (16 kB)
2025-12-07 16:53:33: Using cached idna-3.11-py3-none-any.whl (71 kB)
2025-12-07 16:53:33: Using cached typing_extensions-4.15.0-py3-none-any.whl (44 kB)
2025-12-07 16:53:33: Using cached certifi-2025.11.12-py3-none-any.whl (159 kB)
2025-12-07 16:53:33: Using cached networkx-3.2.1-py3-none-any.whl (1.6 MB)
2025-12-07 16:53:33: Using cached pillow-11.3.0-cp39-cp39-win_amd64.whl (7.0 MB)
2025-12-07 16:53:33: Installing collected packages: typing-extensions, safetensors, protobuf, Pillow, numpy, networkx, idna, h11, certifi, opt-einsum, httpcore, exceptiongroup, anyio, httpx, paddlepaddle
2025-12-07 16:53:41: Successfully installed Pillow-11.3.0 anyio-4.12.0 certifi-2025.11.12 exceptiongroup-1.3.1 h11-0.16.0 httpcore-1.0.9 httpx-0.28.1 idna-3.11 networkx-3.2.1 numpy-2.0.2 opt-einsum-3.3.0 paddlepaddle-3.2.2 protobuf-6.33.2 safetensors-0.7.0 typing-extensions-4.15.0
2025-12-07 16:53:41: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\numpy already exists. Specify --upgrade to force replacement.
2025-12-07 16:53:41: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\numpy.libs already exists. Specify --upgrade to force replacement.
2025-12-07 16:53:41: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\bin already exists. Specify --upgrade to force replacement.
2025-12-07 16:53:42: (✅ checked) done
2025-12-07 16:53:42: - Installing PaddleOCR, the OCR toolkit based on PaddlePaddle...Collecting paddleocr==2.7.0.3
2025-12-07 16:53:42: Using cached paddleocr-2.7.0.3-py3-none-any.whl.metadata (26 kB)
2025-12-07 16:53:42: Collecting shapely (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached shapely-2.0.7-cp39-cp39-win_amd64.whl.metadata (7.1 kB)
2025-12-07 16:53:42: Collecting scikit-image (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached scikit_image-0.24.0-cp39-cp39-win_amd64.whl.metadata (14 kB)
2025-12-07 16:53:42: Collecting imgaug (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached imgaug-0.4.0-py2.py3-none-any.whl.metadata (1.8 kB)
2025-12-07 16:53:42: Collecting pyclipper (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached pyclipper-1.3.0.post6-cp39-cp39-win_amd64.whl.metadata (9.2 kB)
2025-12-07 16:53:42: Collecting lmdb (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached lmdb-1.7.5-cp39-cp39-win_amd64.whl.metadata (1.4 kB)
2025-12-07 16:53:42: Collecting tqdm (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached tqdm-4.67.1-py3-none-any.whl.metadata (57 kB)
2025-12-07 16:53:42: Collecting numpy (from paddleocr==2.7.0.3)
2025-12-07 16:53:42: Using cached numpy-2.0.2-cp39-cp39-win_amd64.whl.metadata (59 kB)
2025-12-07 16:53:43: Collecting visualdl (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached visualdl-2.5.3-py3-none-any.whl.metadata (25 kB)
2025-12-07 16:53:43: Collecting rapidfuzz (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached rapidfuzz-3.13.0-cp39-cp39-win_amd64.whl.metadata (12 kB)
2025-12-07 16:53:43: Collecting opencv-python<=4.6.0.66 (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached opencv_python-4.6.0.66-cp36-abi3-win_amd64.whl.metadata (18 kB)
2025-12-07 16:53:43: Collecting opencv-contrib-python<=4.6.0.66 (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached opencv_contrib_python-4.6.0.66-cp36-abi3-win_amd64.whl.metadata (18 kB)
2025-12-07 16:53:43: Collecting cython (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached cython-3.2.2-cp39-cp39-win_amd64.whl.metadata (5.1 kB)
2025-12-07 16:53:43: Collecting lxml (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached lxml-6.0.2-cp39-cp39-win_amd64.whl.metadata (3.7 kB)
2025-12-07 16:53:43: Collecting premailer (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached premailer-3.10.0-py2.py3-none-any.whl.metadata (15 kB)
2025-12-07 16:53:43: Collecting openpyxl (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached openpyxl-3.1.5-py2.py3-none-any.whl.metadata (2.5 kB)
2025-12-07 16:53:43: Collecting attrdict (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached attrdict-2.0.1-py2.py3-none-any.whl.metadata (6.7 kB)
2025-12-07 16:53:43: Collecting PyMuPDF<1.21.0 (from paddleocr==2.7.0.3)
2025-12-07 16:53:43: Using cached PyMuPDF-1.20.2-cp39-cp39-win_amd64.whl.metadata (8.5 kB)
2025-12-07 16:53:44: Collecting Pillow>=10.0.0 (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached pillow-11.3.0-cp39-cp39-win_amd64.whl.metadata (9.2 kB)
2025-12-07 16:53:44: Collecting pyyaml (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached pyyaml-6.0.3-cp39-cp39-win_amd64.whl.metadata (2.4 kB)
2025-12-07 16:53:44: Collecting python-docx (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached python_docx-1.2.0-py3-none-any.whl.metadata (2.0 kB)
2025-12-07 16:53:44: Collecting beautifulsoup4 (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached beautifulsoup4-4.14.3-py3-none-any.whl.metadata (3.8 kB)
2025-12-07 16:53:44: Collecting fonttools>=4.24.0 (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached fonttools-4.60.1-cp39-cp39-win_amd64.whl.metadata (114 kB)
2025-12-07 16:53:44: Collecting fire>=0.3.0 (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached fire-0.7.1-py3-none-any.whl.metadata (5.8 kB)
2025-12-07 16:53:44: Collecting pdf2docx (from paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached pdf2docx-0.5.8-py3-none-any.whl.metadata (3.2 kB)
2025-12-07 16:53:44: Collecting termcolor (from fire>=0.3.0->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached termcolor-3.1.0-py3-none-any.whl.metadata (6.4 kB)
2025-12-07 16:53:44: Collecting six (from attrdict->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached six-1.17.0-py2.py3-none-any.whl.metadata (1.7 kB)
2025-12-07 16:53:44: Collecting soupsieve>=1.6.1 (from beautifulsoup4->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached soupsieve-2.8-py3-none-any.whl.metadata (4.6 kB)
2025-12-07 16:53:44: Collecting typing-extensions>=4.0.0 (from beautifulsoup4->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached typing_extensions-4.15.0-py3-none-any.whl.metadata (3.3 kB)
2025-12-07 16:53:44: Collecting scipy (from imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached scipy-1.13.1-cp39-cp39-win_amd64.whl.metadata (60 kB)
2025-12-07 16:53:44: Collecting matplotlib (from imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached matplotlib-3.9.4-cp39-cp39-win_amd64.whl.metadata (11 kB)
2025-12-07 16:53:44: Collecting imageio (from imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached imageio-2.37.2-py3-none-any.whl.metadata (9.7 kB)
2025-12-07 16:53:44: Collecting networkx>=2.8 (from scikit-image->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached networkx-3.2.1-py3-none-any.whl.metadata (5.2 kB)
2025-12-07 16:53:44: Collecting tifffile>=2022.8.12 (from scikit-image->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached tifffile-2024.8.30-py3-none-any.whl.metadata (31 kB)
2025-12-07 16:53:44: Collecting packaging>=21 (from scikit-image->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached packaging-25.0-py3-none-any.whl.metadata (3.3 kB)
2025-12-07 16:53:44: Collecting lazy-loader>=0.4 (from scikit-image->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached lazy_loader-0.4-py3-none-any.whl.metadata (7.6 kB)
2025-12-07 16:53:44: Collecting contourpy>=1.0.1 (from matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached contourpy-1.3.0-cp39-cp39-win_amd64.whl.metadata (5.4 kB)
2025-12-07 16:53:44: Collecting cycler>=0.10 (from matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached cycler-0.12.1-py3-none-any.whl.metadata (3.8 kB)
2025-12-07 16:53:44: Collecting kiwisolver>=1.3.1 (from matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:44: Using cached kiwisolver-1.4.7-cp39-cp39-win_amd64.whl.metadata (6.4 kB)
2025-12-07 16:53:45: Collecting pyparsing>=2.3.1 (from matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached pyparsing-3.2.5-py3-none-any.whl.metadata (5.0 kB)
2025-12-07 16:53:45: Collecting python-dateutil>=2.7 (from matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached python_dateutil-2.9.0.post0-py2.py3-none-any.whl.metadata (8.4 kB)
2025-12-07 16:53:45: Collecting importlib-resources>=3.2.0 (from matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached importlib_resources-6.5.2-py3-none-any.whl.metadata (3.9 kB)
2025-12-07 16:53:45: Collecting zipp>=3.1.0 (from importlib-resources>=3.2.0->matplotlib->imgaug->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached zipp-3.23.0-py3-none-any.whl.metadata (3.6 kB)
2025-12-07 16:53:45: Collecting et-xmlfile (from openpyxl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached et_xmlfile-2.0.0-py3-none-any.whl.metadata (2.7 kB)
2025-12-07 16:53:45: Collecting opencv-python-headless>=4.5 (from pdf2docx->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached opencv_python_headless-4.12.0.88-cp37-abi3-win_amd64.whl.metadata (20 kB)
2025-12-07 16:53:45: Collecting cssselect (from premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached cssselect-1.3.0-py3-none-any.whl.metadata (2.6 kB)
2025-12-07 16:53:45: Collecting cssutils (from premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached cssutils-2.11.1-py3-none-any.whl.metadata (8.7 kB)
2025-12-07 16:53:45: Collecting requests (from premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached requests-2.32.5-py3-none-any.whl.metadata (4.9 kB)
2025-12-07 16:53:45: Collecting cachetools (from premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached cachetools-6.2.2-py3-none-any.whl.metadata (5.6 kB)
2025-12-07 16:53:45: Collecting more-itertools (from cssutils->premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached more_itertools-10.8.0-py3-none-any.whl.metadata (39 kB)
2025-12-07 16:53:45: Collecting charset_normalizer<4,>=2 (from requests->premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached charset_normalizer-3.4.4-cp39-cp39-win_amd64.whl.metadata (38 kB)
2025-12-07 16:53:45: Collecting idna<4,>=2.5 (from requests->premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached idna-3.11-py3-none-any.whl.metadata (8.4 kB)
2025-12-07 16:53:45: Collecting urllib3<3,>=1.21.1 (from requests->premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached urllib3-2.6.0-py3-none-any.whl.metadata (6.6 kB)
2025-12-07 16:53:45: Collecting certifi>=2017.4.17 (from requests->premailer->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached certifi-2025.11.12-py3-none-any.whl.metadata (2.5 kB)
2025-12-07 16:53:45: Collecting colorama (from tqdm->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB)
2025-12-07 16:53:45: Collecting bce-python-sdk (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached bce_python_sdk-0.9.55-py3-none-any.whl.metadata (416 bytes)
2025-12-07 16:53:45: Collecting flask>=1.1.1 (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached flask-3.1.2-py3-none-any.whl.metadata (3.2 kB)
2025-12-07 16:53:45: Collecting Flask-Babel>=3.0.0 (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached flask_babel-4.0.0-py3-none-any.whl.metadata (1.9 kB)
2025-12-07 16:53:45: Collecting protobuf>=3.20.0 (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached protobuf-6.33.2-cp39-cp39-win_amd64.whl.metadata (593 bytes)
2025-12-07 16:53:45: Collecting pandas (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached pandas-2.3.3-cp39-cp39-win_amd64.whl.metadata (19 kB)
2025-12-07 16:53:45: Collecting rarfile (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:45: Using cached rarfile-4.2-py3-none-any.whl.metadata (4.4 kB)
2025-12-07 16:53:46: Collecting psutil (from visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached psutil-7.1.3-cp37-abi3-win_amd64.whl.metadata (23 kB)
2025-12-07 16:53:46: Collecting blinker>=1.9.0 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached blinker-1.9.0-py3-none-any.whl.metadata (1.6 kB)
2025-12-07 16:53:46: Collecting click>=8.1.3 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached click-8.1.8-py3-none-any.whl.metadata (2.3 kB)
2025-12-07 16:53:46: Collecting importlib-metadata>=3.6.0 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached importlib_metadata-8.7.0-py3-none-any.whl.metadata (4.8 kB)
2025-12-07 16:53:46: Collecting itsdangerous>=2.2.0 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached itsdangerous-2.2.0-py3-none-any.whl.metadata (1.9 kB)
2025-12-07 16:53:46: Collecting jinja2>=3.1.2 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached jinja2-3.1.6-py3-none-any.whl.metadata (2.9 kB)
2025-12-07 16:53:46: Collecting markupsafe>=2.1.1 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached markupsafe-3.0.3-cp39-cp39-win_amd64.whl.metadata (2.8 kB)
2025-12-07 16:53:46: Collecting werkzeug>=3.1.0 (from flask>=1.1.1->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached werkzeug-3.1.4-py3-none-any.whl.metadata (4.0 kB)
2025-12-07 16:53:46: Collecting Babel>=2.12 (from Flask-Babel>=3.0.0->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached babel-2.17.0-py3-none-any.whl.metadata (2.0 kB)
2025-12-07 16:53:46: Collecting pytz>=2022.7 (from Flask-Babel>=3.0.0->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached pytz-2025.2-py2.py3-none-any.whl.metadata (22 kB)
2025-12-07 16:53:46: Collecting pycryptodome>=3.8.0 (from bce-python-sdk->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached pycryptodome-3.23.0-cp37-abi3-win_amd64.whl.metadata (3.5 kB)
2025-12-07 16:53:46: Collecting future>=0.6.0 (from bce-python-sdk->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached future-1.0.0-py3-none-any.whl.metadata (4.0 kB)
2025-12-07 16:53:46: Collecting tzdata>=2022.7 (from pandas->visualdl->paddleocr==2.7.0.3)
2025-12-07 16:53:46: Using cached tzdata-2025.2-py2.py3-none-any.whl.metadata (1.4 kB)
2025-12-07 16:53:46: Using cached paddleocr-2.7.0.3-py3-none-any.whl (465 kB)
2025-12-07 16:53:46: Using cached opencv_contrib_python-4.6.0.66-cp36-abi3-win_amd64.whl (42.5 MB)
2025-12-07 16:53:46: Using cached opencv_python-4.6.0.66-cp36-abi3-win_amd64.whl (35.6 MB)
2025-12-07 16:53:46: Using cached PyMuPDF-1.20.2-cp39-cp39-win_amd64.whl (6.6 MB)
2025-12-07 16:53:46: Using cached fire-0.7.1-py3-none-any.whl (115 kB)
2025-12-07 16:53:46: Using cached fonttools-4.60.1-cp39-cp39-win_amd64.whl (1.5 MB)
2025-12-07 16:53:46: Using cached numpy-2.0.2-cp39-cp39-win_amd64.whl (15.9 MB)
2025-12-07 16:53:46: Using cached pillow-11.3.0-cp39-cp39-win_amd64.whl (7.0 MB)
2025-12-07 16:53:46: Using cached attrdict-2.0.1-py2.py3-none-any.whl (9.9 kB)
2025-12-07 16:53:46: Using cached beautifulsoup4-4.14.3-py3-none-any.whl (107 kB)
2025-12-07 16:53:46: Using cached soupsieve-2.8-py3-none-any.whl (36 kB)
2025-12-07 16:53:46: Using cached typing_extensions-4.15.0-py3-none-any.whl (44 kB)
2025-12-07 16:53:46: Using cached cython-3.2.2-cp39-cp39-win_amd64.whl (2.8 MB)
2025-12-07 16:53:46: Using cached imgaug-0.4.0-py2.py3-none-any.whl (948 kB)
2025-12-07 16:53:46: Using cached scikit_image-0.24.0-cp39-cp39-win_amd64.whl (12.9 MB)
2025-12-07 16:53:46: Using cached imageio-2.37.2-py3-none-any.whl (317 kB)
2025-12-07 16:53:46: Using cached lazy_loader-0.4-py3-none-any.whl (12 kB)
2025-12-07 16:53:46: Using cached networkx-3.2.1-py3-none-any.whl (1.6 MB)
2025-12-07 16:53:46: Using cached packaging-25.0-py3-none-any.whl (66 kB)
2025-12-07 16:53:46: Using cached scipy-1.13.1-cp39-cp39-win_amd64.whl (46.2 MB)
2025-12-07 16:53:46: Using cached tifffile-2024.8.30-py3-none-any.whl (227 kB)
2025-12-07 16:53:46: Using cached lmdb-1.7.5-cp39-cp39-win_amd64.whl (99 kB)
2025-12-07 16:53:46: Using cached lxml-6.0.2-cp39-cp39-win_amd64.whl (4.0 MB)
2025-12-07 16:53:46: Using cached matplotlib-3.9.4-cp39-cp39-win_amd64.whl (7.8 MB)
2025-12-07 16:53:46: Using cached contourpy-1.3.0-cp39-cp39-win_amd64.whl (211 kB)
2025-12-07 16:53:46: Using cached cycler-0.12.1-py3-none-any.whl (8.3 kB)
2025-12-07 16:53:46: Using cached importlib_resources-6.5.2-py3-none-any.whl (37 kB)
2025-12-07 16:53:46: Using cached kiwisolver-1.4.7-cp39-cp39-win_amd64.whl (55 kB)
2025-12-07 16:53:46: Using cached pyparsing-3.2.5-py3-none-any.whl (113 kB)
2025-12-07 16:53:46: Using cached python_dateutil-2.9.0.post0-py2.py3-none-any.whl (229 kB)
2025-12-07 16:53:46: Using cached six-1.17.0-py2.py3-none-any.whl (11 kB)
2025-12-07 16:53:46: Using cached zipp-3.23.0-py3-none-any.whl (10 kB)
2025-12-07 16:53:46: Using cached openpyxl-3.1.5-py2.py3-none-any.whl (250 kB)
2025-12-07 16:53:46: Using cached et_xmlfile-2.0.0-py3-none-any.whl (18 kB)
2025-12-07 16:53:46: Using cached pdf2docx-0.5.8-py3-none-any.whl (132 kB)
2025-12-07 16:53:46: Using cached opencv_python_headless-4.12.0.88-cp37-abi3-win_amd64.whl (38.9 MB)
2025-12-07 16:53:46: Using cached python_docx-1.2.0-py3-none-any.whl (252 kB)
2025-12-07 16:53:46: Using cached premailer-3.10.0-py2.py3-none-any.whl (19 kB)
2025-12-07 16:53:46: Using cached cachetools-6.2.2-py3-none-any.whl (11 kB)
2025-12-07 16:53:46: Using cached cssselect-1.3.0-py3-none-any.whl (18 kB)
2025-12-07 16:53:46: Using cached cssutils-2.11.1-py3-none-any.whl (385 kB)
2025-12-07 16:53:46: Using cached more_itertools-10.8.0-py3-none-any.whl (69 kB)
2025-12-07 16:53:46: Using cached pyclipper-1.3.0.post6-cp39-cp39-win_amd64.whl (110 kB)
2025-12-07 16:53:46: Using cached pyyaml-6.0.3-cp39-cp39-win_amd64.whl (158 kB)
2025-12-07 16:53:46: Using cached rapidfuzz-3.13.0-cp39-cp39-win_amd64.whl (1.6 MB)
2025-12-07 16:53:46: Using cached requests-2.32.5-py3-none-any.whl (64 kB)
2025-12-07 16:53:46: Using cached charset_normalizer-3.4.4-cp39-cp39-win_amd64.whl (107 kB)
2025-12-07 16:53:46: Using cached idna-3.11-py3-none-any.whl (71 kB)
2025-12-07 16:53:46: Using cached urllib3-2.6.0-py3-none-any.whl (131 kB)
2025-12-07 16:53:46: Using cached certifi-2025.11.12-py3-none-any.whl (159 kB)
2025-12-07 16:53:46: Using cached shapely-2.0.7-cp39-cp39-win_amd64.whl (1.4 MB)
2025-12-07 16:53:46: Using cached termcolor-3.1.0-py3-none-any.whl (7.7 kB)
2025-12-07 16:53:46: Using cached tqdm-4.67.1-py3-none-any.whl (78 kB)
2025-12-07 16:53:46: Using cached colorama-0.4.6-py2.py3-none-any.whl (25 kB)
2025-12-07 16:53:46: Using cached visualdl-2.5.3-py3-none-any.whl (6.3 MB)
2025-12-07 16:53:46: Using cached flask-3.1.2-py3-none-any.whl (103 kB)
2025-12-07 16:53:46: Using cached blinker-1.9.0-py3-none-any.whl (8.5 kB)
2025-12-07 16:53:46: Using cached click-8.1.8-py3-none-any.whl (98 kB)
2025-12-07 16:53:46: Using cached flask_babel-4.0.0-py3-none-any.whl (9.6 kB)
2025-12-07 16:53:46: Using cached babel-2.17.0-py3-none-any.whl (10.2 MB)
2025-12-07 16:53:46: Using cached importlib_metadata-8.7.0-py3-none-any.whl (27 kB)
2025-12-07 16:53:46: Using cached itsdangerous-2.2.0-py3-none-any.whl (16 kB)
2025-12-07 16:53:46: Using cached jinja2-3.1.6-py3-none-any.whl (134 kB)
2025-12-07 16:53:46: Using cached markupsafe-3.0.3-cp39-cp39-win_amd64.whl (15 kB)
2025-12-07 16:53:46: Using cached protobuf-6.33.2-cp39-cp39-win_amd64.whl (436 kB)
2025-12-07 16:53:46: Using cached pytz-2025.2-py2.py3-none-any.whl (509 kB)
2025-12-07 16:53:46: Using cached werkzeug-3.1.4-py3-none-any.whl (224 kB)
2025-12-07 16:53:46: Using cached bce_python_sdk-0.9.55-py3-none-any.whl (390 kB)
2025-12-07 16:53:46: Using cached future-1.0.0-py3-none-any.whl (491 kB)
2025-12-07 16:53:46: Using cached pycryptodome-3.23.0-cp37-abi3-win_amd64.whl (1.8 MB)
2025-12-07 16:53:46: Using cached pandas-2.3.3-cp39-cp39-win_amd64.whl (11.4 MB)
2025-12-07 16:53:46: Using cached tzdata-2025.2-py2.py3-none-any.whl (347 kB)
2025-12-07 16:53:46: Using cached psutil-7.1.3-cp37-abi3-win_amd64.whl (247 kB)
2025-12-07 16:53:46: Using cached rarfile-4.2-py3-none-any.whl (29 kB)
2025-12-07 16:53:47: Installing collected packages: pytz, pyclipper, lmdb, zipp, urllib3, tzdata, typing-extensions, termcolor, soupsieve, six, rarfile, rapidfuzz, pyyaml, pyparsing, PyMuPDF, pycryptodome, psutil, protobuf, Pillow, packaging, numpy, networkx, more-itertools, markupsafe, lxml, kiwisolver, itsdangerous, idna, future, fonttools, et-xmlfile, cython, cycler, cssselect, colorama, charset_normalizer, certifi, cachetools, blinker, Babel, werkzeug, tqdm, tifffile, shapely, scipy, requests, python-docx, python-dateutil, openpyxl, opencv-python-headless, opencv-python, opencv-contrib-python, lazy-loader, jinja2, importlib-resources, importlib-metadata, imageio, fire, cssutils, contourpy, click, beautifulsoup4, bce-python-sdk, attrdict, scikit-image, premailer, pdf2docx, pandas, matplotlib, flask, imgaug, Flask-Babel, visualdl, paddleocr
2025-12-07 16:54:06: Successfully installed Babel-2.17.0 Flask-Babel-4.0.0 Pillow-11.3.0 PyMuPDF-1.20.2 attrdict-2.0.1 bce-python-sdk-0.9.55 beautifulsoup4-4.14.3 blinker-1.9.0 cachetools-6.2.2 certifi-2025.11.12 charset_normalizer-3.4.4 click-8.1.8 colorama-0.4.6 contourpy-1.3.0 cssselect-1.3.0 cssutils-2.11.1 cycler-0.12.1 cython-3.2.2 et-xmlfile-2.0.0 fire-0.7.1 flask-3.1.2 fonttools-4.60.1 future-1.0.0 idna-3.11 imageio-2.37.2 imgaug-0.4.0 importlib-metadata-8.7.0 importlib-resources-6.5.2 itsdangerous-2.2.0 jinja2-3.1.6 kiwisolver-1.4.7 lazy-loader-0.4 lmdb-1.7.5 lxml-6.0.2 markupsafe-3.0.3 matplotlib-3.9.4 more-itertools-10.8.0 networkx-3.2.1 numpy-2.0.2 opencv-contrib-python-4.6.0.66 opencv-python-4.6.0.66 opencv-python-headless-4.12.0.88 openpyxl-3.1.5 packaging-25.0 paddleocr-2.7.0.3 pandas-2.3.3 pdf2docx-0.5.8 premailer-3.10.0 protobuf-6.33.2 psutil-7.1.3 pyclipper-1.3.0.post6 pycryptodome-3.23.0 pyparsing-3.2.5 python-dateutil-2.9.0.post0 python-docx-1.2.0 pytz-2025.2 pyyaml-6.0.3 rapidfuzz-3.13.0 rarfile-4.2 requests-2.32.5 scikit-image-0.24.0 scipy-1.13.1 shapely-2.0.7 six-1.17.0 soupsieve-2.8 termcolor-3.1.0 tifffile-2024.8.30 tqdm-4.67.1 typing-extensions-4.15.0 tzdata-2025.2 urllib3-2.6.0 visualdl-2.5.3 werkzeug-3.1.4 zipp-3.23.0
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\certifi already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\certifi-2025.11.12.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\google already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\idna already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\idna-3.11.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\networkx already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\networkx-3.2.1.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\numpy already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\numpy-2.0.2-cp39-cp39-win_amd64.whl already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\numpy-2.0.2.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\numpy.libs already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\PIL already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\pillow-11.3.0.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\protobuf-6.33.2.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\typing_extensions-4.15.0.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\typing_extensions.py already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\pycache already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:06: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\bin already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:08: (✅ checked) done
2025-12-07 16:54:08: - Installing imutils, the image utilities library...Collecting imutils
2025-12-07 16:54:08: Using cached imutils-0.5.4-py3-none-any.whl
2025-12-07 16:54:08: Installing collected packages: imutils
2025-12-07 16:54:08: Successfully installed imutils-0.5.4
2025-12-07 16:54:08: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\bin already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:09: (✅ checked) done
2025-12-07 16:54:09: - Installing OpenCV, the Computer Vision library for Python...Already installed
2025-12-07 16:54:10: - Installing the CodeProject.AI SDK...Collecting CodeProject-AI-SDK
2025-12-07 16:54:10: Using cached codeproject_ai_sdk-0.0.21-py3-none-any.whl.metadata (931 bytes)
2025-12-07 16:54:10: Collecting Pillow (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached pillow-11.3.0-cp39-cp39-win_amd64.whl.metadata (9.2 kB)
2025-12-07 16:54:10: Collecting charset-normalizer (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached charset_normalizer-3.4.4-cp39-cp39-win_amd64.whl.metadata (38 kB)
2025-12-07 16:54:10: Collecting commentjson (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached commentjson-0.9.0-py3-none-any.whl
2025-12-07 16:54:10: Collecting aiohttp (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached aiohttp-3.13.2-cp39-cp39-win_amd64.whl.metadata (8.4 kB)
2025-12-07 16:54:10: Collecting aiofiles (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached aiofiles-25.1.0-py3-none-any.whl.metadata (6.3 kB)
2025-12-07 16:54:10: Collecting py-cpuinfo (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached py_cpuinfo-9.0.0-py3-none-any.whl.metadata (794 bytes)
2025-12-07 16:54:10: Collecting requests (from CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached requests-2.32.5-py3-none-any.whl.metadata (4.9 kB)
2025-12-07 16:54:10: Collecting aiohappyeyeballs>=2.5.0 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:10: Using cached aiohappyeyeballs-2.6.1-py3-none-any.whl.metadata (5.9 kB)
2025-12-07 16:54:11: Collecting aiosignal>=1.4.0 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached aiosignal-1.4.0-py3-none-any.whl.metadata (3.7 kB)
2025-12-07 16:54:11: Collecting async-timeout<6.0,>=4.0 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached async_timeout-5.0.1-py3-none-any.whl.metadata (5.1 kB)
2025-12-07 16:54:11: Collecting attrs>=17.3.0 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached attrs-25.4.0-py3-none-any.whl.metadata (10 kB)
2025-12-07 16:54:11: Collecting frozenlist>=1.1.1 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached frozenlist-1.8.0-cp39-cp39-win_amd64.whl.metadata (21 kB)
2025-12-07 16:54:11: Collecting multidict<7.0,>=4.5 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached multidict-6.7.0-cp39-cp39-win_amd64.whl.metadata (5.5 kB)
2025-12-07 16:54:11: Collecting propcache>=0.2.0 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached propcache-0.4.1-cp39-cp39-win_amd64.whl.metadata (14 kB)
2025-12-07 16:54:11: Collecting yarl<2.0,>=1.17.0 (from aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached yarl-1.22.0-cp39-cp39-win_amd64.whl.metadata (77 kB)
2025-12-07 16:54:11: Collecting typing-extensions>=4.1.0 (from multidict<7.0,>=4.5->aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached typing_extensions-4.15.0-py3-none-any.whl.metadata (3.3 kB)
2025-12-07 16:54:11: Collecting idna>=2.0 (from yarl<2.0,>=1.17.0->aiohttp->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached idna-3.11-py3-none-any.whl.metadata (8.4 kB)
2025-12-07 16:54:11: Collecting lark-parser<0.8.0,>=0.7.1 (from commentjson->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached lark_parser-0.7.8-py2.py3-none-any.whl
2025-12-07 16:54:11: Collecting urllib3<3,>=1.21.1 (from requests->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached urllib3-2.6.0-py3-none-any.whl.metadata (6.6 kB)
2025-12-07 16:54:11: Collecting certifi>=2017.4.17 (from requests->CodeProject-AI-SDK)
2025-12-07 16:54:11: Using cached certifi-2025.11.12-py3-none-any.whl.metadata (2.5 kB)
2025-12-07 16:54:11: Using cached codeproject_ai_sdk-0.0.21-py3-none-any.whl (39 kB)
2025-12-07 16:54:11: Using cached aiofiles-25.1.0-py3-none-any.whl (14 kB)
2025-12-07 16:54:11: Using cached aiohttp-3.13.2-cp39-cp39-win_amd64.whl (456 kB)
2025-12-07 16:54:11: Using cached async_timeout-5.0.1-py3-none-any.whl (6.2 kB)
2025-12-07 16:54:11: Using cached multidict-6.7.0-cp39-cp39-win_amd64.whl (46 kB)
2025-12-07 16:54:11: Using cached yarl-1.22.0-cp39-cp39-win_amd64.whl (87 kB)
2025-12-07 16:54:11: Using cached aiohappyeyeballs-2.6.1-py3-none-any.whl (15 kB)
2025-12-07 16:54:11: Using cached aiosignal-1.4.0-py3-none-any.whl (7.5 kB)
2025-12-07 16:54:11: Using cached attrs-25.4.0-py3-none-any.whl (67 kB)
2025-12-07 16:54:11: Using cached frozenlist-1.8.0-cp39-cp39-win_amd64.whl (44 kB)
2025-12-07 16:54:11: Using cached idna-3.11-py3-none-any.whl (71 kB)
2025-12-07 16:54:11: Using cached propcache-0.4.1-cp39-cp39-win_amd64.whl (41 kB)
2025-12-07 16:54:11: Using cached typing_extensions-4.15.0-py3-none-any.whl (44 kB)
2025-12-07 16:54:11: Using cached charset_normalizer-3.4.4-cp39-cp39-win_amd64.whl (107 kB)
2025-12-07 16:54:11: Using cached pillow-11.3.0-cp39-cp39-win_amd64.whl (7.0 MB)
2025-12-07 16:54:11: Using cached py_cpuinfo-9.0.0-py3-none-any.whl (22 kB)
2025-12-07 16:54:11: Using cached requests-2.32.5-py3-none-any.whl (64 kB)
2025-12-07 16:54:11: Using cached urllib3-2.6.0-py3-none-any.whl (131 kB)
2025-12-07 16:54:11: Using cached certifi-2025.11.12-py3-none-any.whl (159 kB)
2025-12-07 16:54:11: Installing collected packages: py-cpuinfo, lark-parser, urllib3, typing-extensions, propcache, Pillow, idna, frozenlist, commentjson, charset-normalizer, certifi, attrs, async-timeout, aiohappyeyeballs, aiofiles, requests, multidict, aiosignal, yarl, aiohttp, CodeProject-AI-SDK
2025-12-07 16:54:12: Successfully installed CodeProject-AI-SDK-0.0.21 Pillow-11.3.0 aiofiles-25.1.0 aiohappyeyeballs-2.6.1 aiohttp-3.13.2 aiosignal-1.4.0 async-timeout-5.0.1 attrs-25.4.0 certifi-2025.11.12 charset-normalizer-3.4.4 commentjson-0.9.0 frozenlist-1.8.0 idna-3.11 lark-parser-0.7.8 multidict-6.7.0 propcache-0.4.1 py-cpuinfo-9.0.0 requests-2.32.5 typing-extensions-4.15.0 urllib3-2.6.0 yarl-1.22.0
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\certifi already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\certifi-2025.11.12.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\charset_normalizer already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\charset_normalizer-3.4.4.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\idna already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\idna-3.11.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\PIL already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\pillow-11.3.0.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\requests already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\requests-2.32.5.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\typing_extensions-4.15.0.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\typing_extensions.py already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\urllib3 already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\urllib3-2.6.0.dist-info already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\pycache already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:12: WARNING: Target directory C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\Lib\site-packages\bin already exists. Specify --upgrade to force replacement.
2025-12-07 16:54:13: (✅ checked) done
2025-12-07 16:54:13: Scanning modulesettings for downloadable models...No models specified
2025-12-07 16:54:13: Executing post-install script for License Plate Reader
2025-12-07 16:54:13: Applying PaddleOCR patch
2025-12-07 16:54:13: 1 file(s) copied.
2025-12-07 16:54:13: SELF TEST START ======================================================
2025-12-07 16:54:25: INFO: Could not find files for the given pattern(s).
2025-12-07 16:54:25: C:\Program Files\CodeProject\AI\modules\ALPR\bin\windows\python39\venv\lib\site-packages\paddle\utils\cpp_extension\extension_utils.py:718: UserWarning: No ccache found. Please be aware that recompiling all source files may be required. You can download and install ccache from: 2025-12-07 16:54:25: warnings.warn(warning_message)
2025-12-07 16:54:29: Running verify PaddlePaddle program ...
2025-12-07 16:54:29: PaddlePaddle works well on 1 CPU.
2025-12-07 16:54:29: PaddlePaddle is installed successfully! Let's start deep learning with PaddlePaddle now.
2025-12-07 16:54:29: Self-test passed
2025-12-07 16:54:29: SELF TEST END ======================================================
2025-12-07 16:54:29: Module setup time 00:01:10.16
2025-12-07 16:54:29: Setup complete
2025-12-07 16:54:30: Total setup time 00:01:13.98
I looks like the current version of PaddleOCR is not compatible with the ALPR module. Try the below steps
  1. Delete folder C:\Program Files\CodeProject\AI\modules\ALPR\bin
  2. Replace requirements.txt with the attached
  3. Open up a command prompt in admin mode
  4. change directory to
    Code:
    CD C:\Program Files\CodeProject\AI\modules\ALPR
  5. Run this
    Code:
    ..\..\setup.bat
  6. Reboot your PC
  7. This should install a version of PaddleOCR that will work
Reactions: Spooling
Thanks for all the help. I can't fully delete the bin folder as it looks like some of the python files are in use.
