So I bought an IPC-Color4K-T to set up as a sky cam and had no issues with it at all. Got bored with the sky cam after a few weeks so I put it to better use on the boat dock. A while back I posted this thread EmpireTech PTZ425DB glitchy background? about the same issue I'm having on the IPC4KT.
Image quality is terrible. It's a blocky, blurry mess. If I needed this camera to read a boat registration or get a decent identify-quality picture of someone on or near my dock, I'd be out of luck - the camera can't do it.
I've tried different compression, resolutions, frame rate, bit rate, I frame, image adjustments, exposure, noise reduction, receive buffer, everything.
I have gigabit fiber to the house, a 60 ghz gigabit p2p bridge to the dock, and cameras powered by a POE+ switch. I've tested all the ports on the switch - all getting gigabit speed, no packet loss, 1-3 ms pings for thousands of pings.
The problem seems to be that the image gets too busy for the camera to process due to the choppy water in about half of the image. When the water is calm, the picture is perfect. When it's nighttime and the water isn't visible, again, a perfect image. But as soon as there's any chop/ripples in the water, the image becomes an unusable blocky mess as seen in the video below.
I have an old 5442 varifocal on the other end of the dock in the same position/angle looking the other way on the swim platform and it doesn't have any problems. It has a very clear image that isn't affected by waves/ripples/shadows/anything.
Another thing that makes me think the camera just can't process the images is that the camera freezes up or gives a "no signal" status when the bitrate is cranked up and the waves are especially choppy. At night, I never get any "no signal" or any type of pausing/freezing. But as soon as the sun comes up and the chop starts, the no signal error comes back. I've seen a dozen signal losses or more per hour before.
Been using Blue Iris for a couple years now, feel pretty confident that it's not something with the settings or network/cables/etc. Based on my experience with the ptz425db and the responses on that thread, I'm convinced that this is a camera limitation. I expected way more out of a $230 camera.
If anyone has suggestions of what I might be missing, I'd love to hear them. Otherwise, if you're considering any of these newer cameras and you have a busy background - don't buy one. They're useless. The claim that "almost any camera can do well in the daytime" definitely does not apply to the EmpireTech PTZ425DB or the EmpireTech IPC-Color4K-T.
What are the odds that a hikvision camera would handle a busy scene better than the IPC/Dahua cameras?
