Alley coverage
nonono
Jun 8, 2015
25
11
Hi, looking for some tips on a plan I'm working on to cover an alley. I have a garage in an alley and my goals are to both cover the immediate area near my garage and also get good plate/face Identification of the traffic in the area. I see these as different goals because the foreground near my garage doesn't present good angles for face/plates. So, my plan is to use 4 cameras on this alley to accomplish a wide view of the immediate area combined with a zoomed in view of the approaches to catch faces/plates before they are at too steep of an angle. So, two (far, near) facing each direction for four total cameras. My goal is to be able to positively identify people at night while also keeping a broad overview of the general goings on during the day ("did the garbage truck come yet?"). Lighting wise, I'm wondering if motion detected white LEDs might be a good form of deterrence. I'm in a fairly urban area and I get semi-frequent visitors poking around. They're mostly harmless, but I'm thinking light might help. Are there any cameras that incorporate visible light LEDs? I'd prefer to leverage POE for lighting if possible.
TLDR - looking for camera recommendations as well as feedback on my plan. I'm currently considering IPC-T5442T-ZE for all 4 of these cameras. Pic attached of a Nest Cam I tossed up a few months ago while I worked on a more permanent solution.
Here are my general distance recommendations, but switch out the Dahua 5442 series camera to the equivalent 2MP on the 1/2.8" sensor or equivalent Hikvision works as well.
  • 5442 fixed lens 2.8mm or the 4K/X - anything within 10 feet of camera OR as an overview camera
  • T5449H-ASE-D2 2.8mm fixed lens - anything within 10 feet of camera where the object would be in a backlit condition at night
  • 5441F-AS-E2 (AKA Boobie cam) or E3241F-AS-M- great choice for a front door camera. The boobie cam can have one lens pointed down for packages
  • T5241H-AS-PV - Great little active deterrence camera with two way talk. Good for anything within 10 feet of camera or as an overview camera
  • 5442 ZE or 5842-ZE- varifocal up to 13mm- distances up to 40-50 feet (personally I wouldn't go past the 30 foot range but I like things closer)
  • 5442 Z4E - varifocal up to 32mm - anything up to 80-100 feet (personally I wouldn't go past 60 feet but I like things closer)
  • 5241-Z12E - varifocal up to 64mm - anything from 80 feet to almost 200 feet (personally I wouldn't go past 150 feet because I like things closer)
  • 5241-Z12E - for a license plate cam that you would angle up the street to get plates up to about 175 feet away, or up to 220 with additional IR.
  • 49225 PTZ - great auto-track PTZ and in conjunction with an NVR or Blue Iris and the cameras above that you can use as spotter cams to point the PTZ to the correct location to compliment the fixed cams.
You need to get the correct camera for the area trying to be covered. A wide angle 2.8mm to IDENTIFY someone 40 feet away is the wrong camera regardless of how good the camera is. A 2.8mm camera to IDENTIFY someone within 10 feet is a good choice OR it is an overview camera to see something happened but not be able to identify who.
One camera cannot be the be all, see all. Each one is selected for covering a specific area. Most of us here have different brands and types, from fixed cams, to varifocals, to PTZs, each one selected for it's primary purpose and to utilize the strength of that particular camera.
So you will need to identify the distance the camera would be from the activities you want to IDENTIFY on and purchase the correct camera for that distance as an optical zoom.
If you want to see things far away, you need optical zoom, digital zoom only works in the movies and TV...And the optical zoom is done real time - for a varifocal it is a set it and forget it. You cannot go to recorded video and optically zoom in later, at that point it is digital zoom, and the sensors on these cameras are so small which is why digital zoom doesn't work very well after the fact.
Regarding a camera for plates (LPR) - keep in mind that this is a camera dedicated to plates and not an overview camera also. It is as much an art as it is a science. You will need two cameras. For LPR we need to zoom in tight to make the plate as large as possible. For most of us, all you see is the not much more than a vehicle in the entire frame. Now maybe in the right location during the day it might be able to see some other things, but not at night.
At night, we have to run a very fast shutter speed (1/2,000) and in B/W with IR and the image will be black. All you will see are head/tail lights and the plate. Some people can get away with color if they have enough street lights, but most of us cannot. Here is a representative sample of plates I get at night of vehicles traveling about 45MPH at 175 feet from my 2MP camera (that is all that is needed for plates):
Reactions: sebastiantombs
