Looking at the Dahau camera settings there seems to be a lot more granularity (for lack of a better word) to the settings than are in BI. And I have seen a couple of posts where someone has said that a lot of folks are using the cameras AI functions rather than DS or CP UI in BI.
Also I have noticed with the EmpireTech IPC-T5442T-ZE, it senses motion much further away than BI (which for what I am doing right now is preferable).
With that being said, is there a "Best Practice" in whether or not/when to use the camera settings to trigger alerts vs using the built in BI "Motion sensor" setting on the BI "Trigger" page?
Also, if I use the camera settings, do I then change BI to use the "Cameras digital input or motion alarm" for triggers?
From what I have seen in the cameras settings I think I can fine tune what I want to trigger on and then it will send only the triggers that are defined in the settings, Is this correct?
Thanks,
Eric
Thanks,
Eric
