Alerts not populating unless I toggle "Selected Camera Only" filter.
Ri22o
2,352
4,624
Indiana
I am having a weird issue wherein if I go to my LPR group I will see no, or maybe only a few, alerts in the left column. If I select a camera and then the "Selected Camera Only" button then I will see all of the alerts.
Is anyone else having this issue or know of some setting that may be on? I have restarted the BI service a couple times with no change.
It seems to be only in my LPR group and was not behaving this way until recently.
It also does not show anything in the calendar unless the filter is on, as well.
Normal, no filter:
Single camera filter selected:
My suspicion is clip database corruption. I don't know if it will be fixed if you right click a clip and choose Database > Repair/Regenerate but it is worth a try.
I have already done that, with no change. I can try again though.
I am not sure what changed from repairing the DB the other day and today, but they are all there after running it again. :idk:
