F ffzeus n3wb Mar 31, 2020 19 4 Apr 23, 2022 #1 Hello, is it possible to add time frames to the CRITICAL check box? For example, I only want it to override between 2000 and 0600. I apologiz if this is the wrong plae for this question. Thank you.
F ffzeus n3wb Mar 31, 2020 19 4 Apr 23, 2022 #2 Would be nice to be able to do it by day of wee and have a Custom repeat ability also (i.e. every X days).
wittaj IPCT Contributor Apr 28, 2019 30,968 59,387 USA Apr 23, 2022 #3 That is what the profiles are for. Set up a profile for the time you or don't want alerts.
F ffzeus n3wb Mar 31, 2020 19 4 Apr 23, 2022 #4 Ah. Thank you. I will figure that out. I appreciate the reply. Z
