Just trying to figure out is this is a real option.
I have an alarm, don't always trust remote alerting via their cloud server.
I wondered if I can connect the alarm output (via relay), no Volt NOpen or NClosed into a camera. (not sure which camera, I m in the UK, I have lots already but none have terminals)
Do some camera's have DIO inputs, I know some have outputs to trigger an alarm but not sure the other way round.
If so would his then trigger an alert via the camera. I am sure in BI settings I can use the numerous alert option to push notificatons & all the other great options as long as the fundamentals of what I am asking are possible?
As cheap to buy a average camera as a dedicated Wifi alert sender & then integrated in to BI that I already have on phone rather than a separate App.
Thanks I/A
Thanks I/A
