Hi there,
I have recently installed an IPC-EBW81200 with a 64 Gb SD card into int I am usig for recording (on internal SD card) based on motion detection.
Quite often, I have a notification about "Alarm Event: No disk" then few seconds after a "Alarm Event: No diskStop", like if the SD card was removed or not detected anymore.
here is the lof the camera is providing ... do you have the same issue or not and do you know where thic can come from ??
Most of the time it then continues to record, but sometimes the card gots into "Failed" status and I need to format it through the interface then it goes again for some time ... very annoying ...
... see lines 346 and 347
Many Thanks !
Code:
332 System 2016-11-23 06:24:28 Event End {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
333 System 2016-11-23 06:24:19 Event Begin {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
334 System 2016-11-23 06:09:45 Event End {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
335 System 2016-11-23 06:09:31 Event Begin {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
336 System 2016-11-23 06:01:59 Hot swap {"Action":"Insert Device","Device Name":"Disk1"}
337 System 2016-11-23 06:01:56 Save Configuration {"Name":"Network Config"}
338 System 2016-11-23 06:01:49 Save Configuration {"Name":"Encode"}
339 System 2016-11-23 06:01:49 Save Configuration {"Name":"Encode"}
340 System 2016-11-23 06:01:48 Start up {"Reboot Mark":"Abort"}
341 System 2016-11-23 06:01:48 Abort {"Time":"2016-11-23 06:01:20"}
342 System 2016-11-23 05:57:30 Start up {"Reboot Mark":"Abort"}
343 System 2016-11-23 05:57:30 Abort {"Time":"2016-11-23 05:57:01"}
344 System 2016-11-23 05:53:58 Start up {"Reboot Mark":"Abort"}
345 System 2016-11-23 05:53:58 Abort {"Time":"2016-11-23 05:53:30"}
346 System 2016-11-23 05:45:20 Hot swap {"Action":"Insert Device","Device Name":"Disk1"}
347 System 2016-11-23 05:45:15 Hot swap {"Action":"Remove Device","Device Name":"Disk1"}
348 System 2016-11-23 05:33:48 Event End {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
349 System 2016-11-23 05:33:38 Event Begin {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
350 System 2016-11-23 05:08:09 Event End {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
351 System 2016-11-23 05:08:00 Event Begin {"Channel NO.":1,"Event Type":"Motion Detect","Region Name":["Region1"]}
Many Thanks !
