Hi guys, I currently have installed a Aiphone JF-DVF Door Station and a JB-2MD Master Indoor Station. The current intercom is old, and working sporadically. So, I intend to replace it with a Aiphone JOS-1FW Video Intercom Flush Mount Vandal Door Station Kit.
The current wiring looks fine, but when I read the literature of the unit I intend to replace it with, it states for the Master Station Power Supply which is an 18Volt DC that "Without Grounding, the stations may not work properly" Is this necessary, the current wiring on the JB-2MD is two wire solid cire, but has not ground terminal. See Image of current.
So the question is this, if I hookup the new Intercom without using a ground, wil it work. If I need to use a ground, how would that also work.
Just need a little guideance.
Thansk
Thansk
