AI Status window always empty
Pentagano
Getting comfortable
Dec 11, 2020
665
300
Uruguay
I am trying out the BI deepstack. All seems to be working - I get the mqtt alerts for the motion detected, DS is running.
I ticked the Save AI analysis details but the status window is always empty.
What am I missing?
Thanks
Bump, I have the same issue.
Can't find anything with Google/Forum search.
EDIT:
I didn't search very hard I suppose.
Just found this:
The tool is intended to be open while reviewing an alert clip (not real time). Double click an alert to watch the playback and AI Analysis at the same time as the clip plays. Works best with two monitors.
Also check out Phillip's reply below that shows where the analysis tool is enabled.
Reactions: Philip Gonzales
Camera Settings>Trigger> Artificial Intelligence.
Check the box for "Save AI analysis details". This will generate .DAT files in your Alert folder. Drag one of those .DAT files into the blank AI Status window and Viola!
