AI Squirrel alerts with Built-in BI AI???
Dec 30, 2020
7
4
utah
With CodeProject AI I could get squirrel AI alerts, but with the new Blue Iris built-in AI I can only get general AI animal alerts and squirrel is not one of them. Is there a customized file that will work with the built-in BI AI or another method to get squirrel AI alerts using the built-in BI AI setup? I don't really want to revert to CodeProject AI/
TIA!
I found the real answer: BI Now supports Custom Models
Reactions: Skinny1
Not sure its working or not but if you go in to the AI tab in the camera and select Additional Models and then select Override Global List you should see ipcam-animal populated in the open field below these options. I walk tested my camera at dusk last night and I was identified as a DOG. Wife said, I told you so. your a dog.
