1 105437 BIT Beta Team Jun 8, 2015 2,231 1,087 Today at 10:59 AM #1 What's the difference between these two models, if any?
MikeLud1 IPCT Contributor Apr 5, 2017 2,814 4,915 Brooklyn, NY Today at 1:02 PM #2 105437 said: What's the difference between these two models, if any? Click to expand... They are the same just different file names.
1 105437 BIT Beta Team Jun 8, 2015 2,231 1,087 Today at 1:16 PM #3 MikeLud1 said: They are the same just different file names. Click to expand... Thanks Mike. Can you provide the link to the latest versions you have. Also, when using your models, is the primary model in BI even used?
MikeLud1 IPCT Contributor Apr 5, 2017 2,814 4,915 Brooklyn, NY Today at 6:41 PM #4 105437 said: Thanks Mike. Can you provide the link to the latest versions you have. Also, when using your models, is the primary model in BI even used? Click to expand... The latest version is included when you download the Models from the below Blue Iris link Reactions: 105437
