AI found license plate number but BI ignored it?
iwanttosee
Pulling my weight
Dec 27, 2020
259
226
US
Log from CodeProject.AI 2.8.0
Line 979: 17:37:21:Response rec'd from License Plate Reader command 'alpr' (...71f201) ['Found Plate: 85A4YW'] took 366ms
Line 984: 17:37:21:Response rec'd from License Plate Reader command 'alpr' (...dc90be) ['Found Plate: 8SA4YW'] took 334ms
Line 989: 17:37:22:Response rec'd from License Plate Reader command 'alpr' (...24bc12) ['Found Plate: 8SA4YW'] took 393ms
Line 1265: 17:39:33:Response rec'd from License Plate Reader command 'alpr' (...05b003) ['Found Plate: CXA6C5A'] took 314ms
Line 1832: 17:42:29:Response rec'd from License Plate Reader command 'alpr' (...f0fc94) ['Found Plate: CXA6C5A'] took 568ms
Line 1904: 17:42:38:Response rec'd from License Plate Reader command 'alpr' (...0d662a) ['Found Plate: AM39283'] took 352ms
What BlueIris picked up. Skipped the 17:37 and 17:39 completely, even though CodeProject.AI found it? Happy to provide any logs, if I know where to find it.
Thanks.
Likely not high enough confidence assigned to the result. What does the AI .dat file indicate for the related alert? Hold Ctrl and double click the alert to see the AI analysis.
Thanks for replying with instruction.
I was only able to get the AI analysis of the alerts so I couldn't see below isn't picked up by BI.
Found another example,
Maybe it has to do with the time delay AI found the plate and when the footage is triggered?
Line 978: 05:44:55:Response rec'd from License Plate Reader command 'alpr' (...b6b829) ['Found Plate: R8A 8BT'] took 299ms
Line 981: 05:44:56:Response rec'd from License Plate Reader command 'alpr' (...8eff78) ['Found Plate: R8A8BT'] took 368ms
Line 984: 05:44:57:Response rec'd from License Plate Reader command 'alpr' (...e8db7d) ['Found Plate: R8A 8BT'] took 334ms
Line 987: 05:44:57:Response rec'd from License Plate Reader command 'alpr' (...c92533) ['Found Plate: R8A 8BT'] took 277ms
